Why body lifts suck
Old May 25, 2009 | 08:35 AM
UKMyers's Avatar
Why body lifts suck
Sweet I fit bigger tires but if I ever I roll this might happen. This happened after a buddy rolled on a gravel road... not even wheeling.
Old May 25, 2009 | 08:39 AM
toyospearo's Avatar
HOLY CRAP!
that sucks dude
I hope he/she was ok.
Old May 25, 2009 | 08:41 AM
algranger's Avatar
Not a fan of body lifts myself but really you cant expect much less in the event of a rollover.. it looks pretty harsh.
Did the bolts break or what? How did the body disconnect?
Old May 25, 2009 | 08:45 AM
tc's Avatar
tc
Here's an idea ...
DON'T ROLL!
UKMyers's Avatar
The driver was pretty banged up but overall okay. I have not looked at the actual truck to see what exactly failed. They installed the body lift themselves so it's hard telling.
Old May 25, 2009 | 09:06 AM
toyNG's Avatar
WOW. Glad to hear everyone is ok. I'd be curious to see where the failure occurred. I know that the length of the body lift blocks create more strain/torque, but it seems like quality bolts would prevent them from completely sheering off, or at least make it no more likely than if there were no body lift at all.
Makes me want to go tighten down all my body lift bolts!!
Old May 25, 2009 | 10:19 AM
TOYOTA 1's Avatar
the title should be called why rolling sucks.
who's to say that wouldn't of happened without the body lift?
the truck would probably had been better off if he rolled while wheeling, rather than cruising down a gravel road. low speed vs high speed right?
glad to here everyone is OK, i hate seeing a yota get destroyed.
Old May 25, 2009 | 10:33 AM
YeloSub7's Avatar
UKMyers, so does this mean you will finally take off your body lift??? You'll still be fine fitting those 37's
Old May 25, 2009 | 11:21 AM
waskillywabbit's Avatar
Grade 8 (10.9) hardware nor a body lift is to blame I bet.
Glad everyone is okay, but anytime you roll, all bets are off.
Old May 25, 2009 | 11:28 AM
UKMyers's Avatar
This truck belonged to a guy back home where I grew up. I just talked to my step dad who looked at it and he said they did not put washers under the bolt heads on the cab....
Yellow sub... Someday I'll remove mine. I will have to throw away my custom front bumper, rebuild my rear bumper mountrs, and cut my sliders off the frame and reweld them though.
Old May 25, 2009 | 11:45 AM
Yep without the washers the load is on just the body sheet metal, just pulled the bolt heads right through pretty easily I bet.
Old May 25, 2009 | 12:15 PM
TOYOTA 1's Avatar
ok another title change, "why rolling with an improperly installed body lift sucks"
Old May 25, 2009 | 12:51 PM
eighty5yota's Avatar
by the damage, it looks like the seperation possibly helped relieve some of the forces that would have crushed the cab. by it breaking free and having mobility on most axis, the loads were probably dispersed .
glad everyone is alive.
p.s. keep the rubber side down.
Old Jun 9, 2009 | 06:41 AM
Gizler00's Avatar
Thats crazy. I still like my BL though. And I def used the washers on the top and bottom of the mounts. I hope everyone is ok.
Old Jun 9, 2009 | 08:57 AM
RobD's Avatar
How many body lifts are installed incorrectly, I wonder?
Old Jun 9, 2009 | 09:01 AM
TOYOTA 1's Avatar
at least one
Old Jun 9, 2009 | 09:51 AM
4Crawler's Avatar
Yep, very crucial step to re-use those factory washers:
- http://www.4crawler.com/4x4/ForSale/...ockBodyWashers
They are special washers, extra thick steel, likely heat treated and they have a very large OD for the size of the hole in the center.
Old Jun 9, 2009 | 09:55 AM
desertcamper67's Avatar
I rolled my first 4Runner 10-12 times down a mountain in '96. Winshield popped out, plastic trim pieces got launched and the fiberglass top was partly torn off at the roll bar but the body lift stayed intact.
The only straight piece of sheetmetal was the gas door.
Old Jun 9, 2009 | 11:10 AM
Teuf's Avatar
i got a 2 inch body lift, never put it on, anyone want it?
Old Jun 9, 2009 | 01:13 PM
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
haha.
