Where to mount ARB compressor?
Old Feb 25, 2006 | 08:00 AM
tc's Avatar
tc
Got my lockers, and started looking...no wide open place waiting for the compressor...Where have y'all mounted compressors?
Old Feb 26, 2006 | 09:38 AM
tc's Avatar
tc
bumpity bump
Nobody has a compressor mounted in their rig?
Old Feb 26, 2006 | 10:25 AM
mt_goat's Avatar
Here's mine, it just touches the hood insulation a little:
http://community.webshots.com/photo/...42310107fKwNmW
Old Feb 26, 2006 | 10:37 AM
tc's Avatar
tc
I think that's the same place I was looking at - where did you move the ignitor to?
Old Feb 26, 2006 | 10:43 AM
mt_goat's Avatar
The ignitor is still there just below the compressor.
Old Feb 26, 2006 | 11:01 AM
tc's Avatar
tc
Hmmmm - which compressor do you have? I got the bigger one (RDCKA).
Also, any writeup or anything on how to remove the third members? I'm having a shop set up the gears/lockers in the third, but need to save the $$$$$ by taking them out myself.
Any help is appreciated - starting to wonder if I bit off more than I can chew!
Old Feb 26, 2006 | 11:13 AM
mt_goat's Avatar
My compressor is pretty old, maybe about 9 years old I guess. So they might be bigger now
I had my lockers installed on the truck by a trusted mechanic, so I've never removed my 3rd.
Old Feb 26, 2006 | 11:24 AM
mt_goat's Avatar
I'm considering moving my compressor now that I'm rearranging my whole engine compartment to put in a 3.4. I'd like to get it somewhere cooler, (like away from the engine) but I'm still searching myself. I thought about under the rear seat but it can puke gear oil sometimes and that would be smelly and messy or in the bed somewhere. Under the truck would be cool but there's a lot of water exposure under there and I wouldn't want to be stuck in a water crossing with no air for the lockers.
Old Feb 26, 2006 | 06:33 PM
RTdawgs's Avatar
Old Feb 26, 2006 | 06:52 PM
tc's Avatar
tc
You guys with 3.4's make me seriously ill. Not only do you have more power and get better gas mileage, but there's actually more room in your engine compartment!
NOT FAIR!!!
Old Mar 15, 2006 | 08:33 PM
^VooDoo^'s Avatar
I mounted mine on the passengerside of engine compartment, The small virtical space near the power antenna.
just pull the relays there and mount them to another area or let them lay.
Also its near the battery.
I spent a time making it look nice, Feels like I wasted my time though, Blew out the ARB right away about 20k fell apart since the locker pins are weak.
Im on diff #4 now.
Old Mar 15, 2006 | 09:49 PM
Elvota's Avatar
I took out the cruise control assembly, and fit mine there. Kinda of hard to see in this pic, but follow the blue line to the drivers side. Didn't have to relocate coil or other components. I had some trouble with oil leaking from the compressor when I put it on it's side (on side in pic). Have since changed position, not placement. Fits just barely vertical, and that is with 1/4" rubber washers underneath bracket to help isolate vibration.
http://i44.photobucket.com/albums/f1...a/DSCN0254.jpg
http://i44.photobucket.com/albums/f1...a/59a4d765.jpg
Remove rear diff: Drain it first. You must pull the axles out just enough to get the diff out. Remove wheels, drum brakes, and then the four bolts per side holding axle to housing. Then pull. Probably want to replace the axle seals and check bearings while your at that point, so just pull the axles out all the way and set aside. All this is assuming you have a V6 3rd.
Undo ABS sensor, all those tiny nuts around the diff and four at the driveshaft. Pull to break the RTV seal, and watch out... it is fairly heavy.
Good luck.
Old Mar 16, 2006 | 11:34 AM
tc's Avatar
tc
I got it in there where Mt Goat has his. Looks pretty good.
Got the front and rear installed. Major air leak IN the rear. No leaks at all for the front. Will have to drop the rear (again) and replace the seal assembly - I think the little copper tube got damaged during install.
Was supposed to do it tonight, but it appears ARB may have sent an RD33 seal assembly (not the RD23). Aaaargh! Guess I'll be 'wheellling Saturday with just the front locker (again). Bummer....
A2theK
Sep 30, 2016 12:50 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
coffey50
Jul 28, 2015 10:55 AM
A2theK
Jul 12, 2015 10:46 AM
skoti89
Jul 8, 2015 12:05 AM
