welded front drive shaft
Old May 6, 2006 | 11:48 PM
chasmc2's Avatar
I just bought a new rig . Now I want to kick you ever did the mods on this truck. I know I should of looked better but just had ankle surgery and wasn’t in the mood to go lay on the ground and check things out at the time. I also was trying to beat the mob of people coming to look at the truck. Well to get to the point they welded and bolted the front and rear drive shafts in. Actually any mod that was done the welder was involved. I just don’t understand what people think once in a while. why would you want to do anything like this? And why on my truck its hard enough for me to crawl under my rig to work on it but now I have to fix bad engineering
Old May 7, 2006 | 07:28 AM
Tanto's Avatar
It seems like all that welding is overkill to me, even if it is a trail rig. You should invest in a good grinder.
Old May 7, 2006 | 07:57 AM
Tanto's Avatar
The jibe I got from his posts was that parts were welded on after they were already bolted on. In specific, if he breaks a driveshaft on the trail or on the road for that matter, now he's going to need to grind the driveshaft off instead of just removing the bolts.
Old May 7, 2006 | 09:39 AM
chasmc2's Avatar
I know that a weld is stronger than nuts and bolts but have you ever snapped all of the bolts in a drive line before breaking something else? I'm just a little pissed that everything is welded Front bumper has tac welds on the bolts, the seats are welded in. and so on.
Old May 7, 2006 | 04:43 PM
Adam F's Avatar
hmmm thats odd, welding the yoke to the flange?
I hope he took the flange off before welding. Might have melted the oil seal. Does it leak at all?
Old May 7, 2006 | 09:17 PM
chasmc2's Avatar
yep it leaks, i just thought that the seal was gone. The play in the tranny sucks the play in the shifter is really bad. can be in 1st and move the shifter sideways to 5th and vice versa plus trying to shift is scarry. not sure if your up shifting or down shifting till you let out the clutch. I'm kicking around thowing in a transfer case and transmission that i have from a 90 4runner. I have to change the transmission mounts on the frame and cut the rear drive shaft but other than that i'm good to go.
Old May 8, 2006 | 08:47 AM
Bobakazi's Avatar
Did he think Toyotas are weak? What a 'tard. Sorry man.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
Jnkml
Jul 6, 2015 01:20 PM
toyoda8488
Jul 5, 2015 10:18 PM
