Water in the Rear Diff
Old Feb 9, 2009 | 10:58 AM
Aywilkerson's Avatar
I found out that my rear pinion seal is leaking on my 91 fj80. nut the oil coming out as a milky color. how do I clean that out. DO I just drain the oil and refill or do I need to pull the axles, drop the third member and clean with WD40?
Old Feb 9, 2009 | 11:12 AM
83's Avatar
83
Seems like a common fix is to drain, spray brake cleaner in, a LOT of brake cleaner, try to get it all over the inside, let it all drain out, maybe overnight, then refill. You can also just change the fluid, run it for a 10 or 20 miles, and change it again. Honestly though most people probably just change the fluid and are done with it. Fix that pinion seal, they aren't that hard (at least not on my truck).
Old Feb 9, 2009 | 11:23 AM
GSGALLANT's Avatar
Just drain and refill. If you're concerned, you can check the condition of the new fluid after a few hundred miles by draining a bit from the drain plug (after the truck has sat for a while). If there's any water left, it will settle to the bottom.
Old Feb 9, 2009 | 05:43 PM
dntsdad's Avatar
Runner some extensions for your breathers!!!
Old Feb 10, 2009 | 07:47 AM
where is a great place to buy one for the best price? will any rear pinion seal work? those axles cant be too much different from my 4 runner right?
Old Feb 10, 2009 | 07:51 AM
83's Avatar
83
Wouldn't think they'd be much different.
Get them from either Toyota or Marlin Crawler. I wouldn't use anything else. It's a cheap part, no need to skimp.
Old Sep 21, 2012 | 07:12 AM
locked fj80's Avatar
just refill it but you also need to reroute the differential breather to the engine compartment to prevent this again
Old Sep 30, 2012 | 04:30 AM
Lawn Dart's Avatar
Drain and refill. If you're seriously concerned, do it twice. There's natural humidity in the air. Personally, I wouldn't be concerned about a left over drop or two. There's no way you're going to eliminate all moisture.
the1998sr5
15
Jul 14, 2020 08:35 PM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
Snort
Jul 19, 2015 07:03 AM
Jonny246
Jul 12, 2015 04:51 AM
