Vinyl tubing, can it handle the heat?
I am about to change out my diffs so it seems like the best time to finally do the front diff breather extension.
For the rear I just shoved some clear ( I wanted to see if gear oil was getting pushed up and getting stuck) vinyl tubing ( 5/16"). I wasnt worried about heat because its so open. On the front the tube is going to be RIGHT against the oil pan, think this stuff will melt?
So Can I use the tubing or should I just forget it and buy some fuel hose instead.
p.s these fittings are impossible to find around here! I got some 1/8th thread brass fittings, they are a micron bigger then the stock breather!
I would suggest that you go with the fuel line. The vinyl tubing is /was used on some of the machines I work on at Intel, it seems to get brittle after being exposed to some temp ranges (150-225*F) As far as the tubing resting against the oil pan, you might be able to use a spring or zip tie to keep it a reasonable distance away...
i used a yellow air compress hose, but in half one for the front and rear. i works good.
and if you dont like the fittings you have try some nissan ones they have a nice long stem on them to attach a hose.
heres the link with the nissan part number, i paid about 7 for both.
http://toyota.off-road.com/toyota/ar....jsp?id=186211
if you do choose to wrap the line by the oil pan I would think that a spring would still transfer alot of heat, maybe some heat wrap like for headers or something. I'd watch that clear tubing just in case. there are a few clear tubes that used to run oil to my jetski that were pretty close to the engine and they did alright, but the did get brittle after a while. I run mixed fuel so they are gone now
kind of a neat idea though!
Well, since the oil pan is so friggin close to the breather the tubing is going to be mighty close. Since I would rather not find out the hard way, im just going to break down and buy some fuel line instead. It wouldve been nice to use this clear stuff though.
gyroscope7
7
09-27-2015 08:39 PM
