Urgent help needed truck wont crank
Old Jan 3, 2012 | 12:46 PM
Batcavee00's Avatar
So my dumass decided to test the starter while it was still on the car. Not on the flywheel. And i guess the starter was touching metal and wen i tryed to crank the starter i saw a spark and then nothing would happen wen i turn the key. I took the starter to autozone and worked great. So now thers no power to the starter.all fuses seem good. So im not sure wat else i blew. Any help would be appreciated.
I got a toyota pickup 1985 22r
Old Jan 3, 2012 | 01:07 PM
creswellhick's Avatar
idk know anything about electrical stuff really but i do know just because a fuse looks good doesnt meen it it good
Old Jan 3, 2012 | 01:35 PM
matstaley's Avatar
Pull that big fuse in the box under the hood just behind the battery and check it with an ohm meter.
Old Jan 3, 2012 | 01:58 PM
Batcavee00's Avatar
The small fuses next to the battery are not burned, and i already tried using ither relays, but no luck. Are there other fuses or relays on the cabin i can possibly test?
Old Jan 3, 2012 | 02:39 PM
85gijunk4x4's Avatar
start tracing wires
Old Jan 3, 2012 | 03:03 PM
matstaley's Avatar
Check the wire coming from your battery to the underside of the fuse box in the engine bay. It might have a fusible link in it. check for 12v at the fuse box.
Old Jan 3, 2012 | 07:02 PM
Batcavee00's Avatar
So thers power to the 80,40,30 amp fuses but no power to the smaller 10 and 7. 5 Fuses. Thers also powwer to the bigger relay. Wat else can i do? Is there like a fuse between the ignition switch and the fuse box by the battery?
Old Jan 3, 2012 | 08:11 PM
matstaley's Avatar
There is an igmition fuse under the dash on the drivers side kick panel
Old Jan 4, 2012 | 07:12 AM
Batcavee00's Avatar
Guys so i checked the driver kickpannel fuses and non are burn. All fuses have power with the ignition on. Maybe my ignition switch got messed up with the short? All lights on dash still light up though. And thanks for all the replies!
Old Jan 4, 2012 | 01:37 PM
Batcavee00's Avatar
Any other suggestions?
slider417
Jun 22, 2015 10:18 AM
LSUMatt1514
60
Oct 10, 2003 12:30 PM
HALMAN
Jun 14, 2002 09:02 PM
