Transmission & T-case leaks/cracks
Old Mar 24, 2009 | 10:37 AM
forwardtocharis's Avatar
Unhappy Transmission & T-case leaks/cracks
So i missed the section on hand-tightening the fill bolt on the transmission and have a hairline crack where the fill bolt goes in. I patched it with some metal filler, but I'm still getting a little bit of oil leaking.
Since that isn't enough, I also made the mistake of letting Jiffy Lube work on the t-case. The filler threads are completely stripped (on the t-case, not the bolt). The bolt is currently held on with some silicone, but it's still leaking and has a crack similar to the tranny.
i was thinking of tack welding the cracks and retapping the filler with a slightly larger size. The drain bolt is also leaking on t-case.
Any thoughts on the best route to go?
Old Mar 24, 2009 | 11:00 AM
SEAIRESCUE's Avatar
Go see the Manager at JL and then confront the gorilla that ruined your transfer case. Will probably be a battle, you word against his, but if the manager has had complaints in the past, he may work with you. If you are unsuccessful, take them to small claims court along with estimates from several shops to replace the case. You have a 50-50 chance of winning.
Other options include tapping the hole to the next size pipe thread. Will likely require the case to be dropped. It can be drilled and tapped upside down and with axle grease on the drill bit to catch the chips. Then the next size tapered pipe thread, with grease on it too, can be used to cut new threads. I suggest you find a automotive machine shop to do the work. I lived there for years and there are some great shops in SD. PS, the new plug should have a magnet for extra protection.
Old Mar 24, 2009 | 11:05 AM
Long story short there's no reasonable way to prove fault.
This might sound ridiculous (but given that I'm a college student who is just getting by, cheap is often best), but could I weld a fine-thread nut on to the t-case on top of the fill hole?
Old Mar 24, 2009 | 11:09 AM
neoworm0's Avatar
Just find another tcase. They're not that hard to find and not that expensive. Especially the rear sections. Find someone who's done duals and grab the back half of the case.
Old Mar 24, 2009 | 11:14 AM
neoworm0's Avatar
here you go.
http://sandiego.craigslist.org/esd/pts/1087231799.html
Old Mar 24, 2009 | 11:19 AM
neoworm0's Avatar
How about this post #9
http://bb.bc4x4.com/showthread.php?t=140168
I have a milk crate full of toy tcase gears plus a bunch of misc toy tcase housings. (No dual case front section) but a bunch of middle sections and rear sections.
$30 takes it all.
Old Mar 24, 2009 | 11:20 AM
neoworm0's Avatar
If you ask him nicely he might ship the section you need.
Old Mar 24, 2009 | 11:29 AM
SEAIRESCUE's Avatar
OK, plan B
Wrap tape, your choice, around the plug threads and tighten it until it starts to loosen. Tape junk will not affect inner parts of tx case. College student cheap and effective. Others may suggest something else but the concept is as cheap and effective as it gets.
If access to the plug is really good, you may find a muffler shop or garage that will weld a nut onto the case. Make a washer out of cardboard to seal the bolt that will be threaded into the nut. Hopefully they will do it for $20 and not set your rig on fire.
Old Mar 24, 2009 | 11:48 AM
neoworm0's Avatar
OK, plan B
Nice and ghetto dude. Better yet just stuff a rag in the hole and call it good.
Old Mar 24, 2009 | 12:02 PM
mt_goat's Avatar
Originally Posted by forwardtocharis
i was thinking of tack welding the cracks...
The cases are made of cast aluminum. Welding up a crack in an aluminum case would be very difficult. The crack will want to open up as it starts to get molten and the heat transfers away very quickly making the whole case very hot. Not like welding steel at all.
I had this same problem with my lawnmower engine drain plug, I drained it completely and used brake cleaner to clean up the threads and used black RTV to seal the plug in. It hasn't leaked a drop since, but I can never remove the plug now. Lucky Briggs & Strat has 2 drain plugs
Old Mar 24, 2009 | 12:10 PM
Thanks for all the responses, not entirely sure what I'm going to do as of yet. I'd love to buy the section and replace it, but living on campus=no where to work on my truck.
I had forgotten that the t-case was aluminum, that reminder just saved a lot of hassle.
Old Mar 24, 2009 | 12:21 PM
neoworm0's Avatar
That's too bad. Better stock up on rags then. Could always try some JB weld.
Old Mar 24, 2009 | 12:54 PM
mikepr55's Avatar
tampons work to that is what my wife uses when she leaks.
ClintonP929
3.4 Swaps
64
Jun 13, 2017 01:46 PM
briholt
Sep 20, 2015 10:26 PM
Rickstwowheels
Sep 18, 2015 03:48 AM
kelly1450
Sep 2, 2015 12:29 PM
