Toyota Says I Need An Induction Service?
Old Apr 3, 2012 | 06:37 AM
jacumja's Avatar
Its $75 and they say I ha e black soot and carbon deposit's. They say its a chemical they run through it. Sounds a lot like a fluffer charge and I'm paying $75 for a bottle of throttle body cleaner. I wanted the opinion of the vet's on here on how to proceed.
Old Apr 3, 2012 | 06:43 AM
waskillywabbit's Avatar
Hit them with your purse
:wabbit2:
Old Apr 3, 2012 | 07:21 AM
jacumja's Avatar
lol wabbit
So whats your suggestion.
Old Apr 3, 2012 | 07:35 AM
jacumja's Avatar
I'm waiting to hear Sea Foam in 3,2,...
Old Apr 3, 2012 | 08:02 AM
There a reason they said you need this like bad mileage or stalling etc?
I still say purse em
:wabbit2:
Old Apr 3, 2012 | 09:03 AM
93toyrunner2's Avatar
SeaFoam
SeaFoam works for me! Under $10 at most auto parts, blows the soot right out of the exhaust.
Old Apr 3, 2012 | 09:27 AM
jacumja's Avatar
no reason besides carbon build up and soot. Also was there for an alignment and two hours later they come back telling me they can't align the truck unless I get a $350 rack and pinion replacement.
Old Apr 3, 2012 | 10:00 AM
snobdds's Avatar
By the look of your runner, it's not a 95.5 + model. Only the 95.5 and newer models have a rack and pinion. Are you sure they didn't say a bad pitman or idler arm?
Old Apr 3, 2012 | 10:30 AM
jacumja's Avatar
mine is a 98 thats an old picture
Old Apr 3, 2012 | 10:40 AM
snobdds's Avatar
Well then I degress...
Most of the time those can be rebuilt with new bushings for far less money...search on here becasue there are lots of threads about it.
Old Apr 3, 2012 | 10:47 AM
badattitude's Avatar
Do it yourself for sure. New air filter, clean MAF with MAF cleaner, clean TB with TB cleaner then run the seafoam
Do not let the TB cleaner in the Intake Air Control IAC, it's the opening infront of the TB butterfly
inject the 1/2 bottle of seafoam into the PVC vacume line. The truck will run rough, it is normal.
You may want to let the seafoam sit for 1 hour.
You will notice a difference if you do all that.
I did all this to mine a few weeks ago.
I like the seafoam but have only used it twice and will not use it again for two-three years.
If you only do one thing, clean the TB. best to take it all the way off the car if you can. Might as well throw on an o ring gasket while the TB is off.
Next best thing is to clean the MAF.
You may also want to check replace the PCV valve too.
Old Apr 3, 2012 | 11:40 AM
MudHippy's Avatar
Anybody try the new imitation Sea Foam?
I seen this stuff other day, so I went home and looked it up online. And, sure enough, it's basically the same as Sea Foam Motor Treatment just a slightly different recipe. But you're supposed to use it the same way.
CRC® Motor Treatment.
http://www.crcindustries.com/auto/?s=05316
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
Snort
Jul 9, 2015 03:58 PM
colinmil
Jul 6, 2015 04:03 PM
