Tacoma Whip Antenna Mod Article Found!
Old May 2, 2007 | 06:26 AM
tmgallagher's Avatar
My electric antenna just went and after pouring through the forums, I know some other people were looking for this article as well.
http://www.4runners.org/writeups/whip/index.html
Enjoy.
Old May 2, 2007 | 08:29 PM
Driftinco's Avatar
Thanks for putting this up! It came in real handy tonight.
Old May 2, 2007 | 08:30 PM
tc's Avatar
tc
Welcome to YT Brian!
Old Sep 15, 2009 | 02:12 PM
scaesare's Avatar
So, this antenna writeup list the following parts:
Antenna Assembly: 86300-35090 (list price $36.94)
Tacoma Whip antenna: 86309-AA040 ($27.38 at my dealership)
It also says: "Please note that the Tacoma Whip Antenna is not picture above. If you want the Tacoma black whip antenna, buy part no. 86309-AA0400 and NOT 86309-35100 or 86309-32011. "
I'm not sure I understand if I need both to replace my broken motorized unit on my 3rd gen ('97) with the black Tacoma whip.
The writeup doesn't seen to address which part does what.
Can anybody hit me with a cluestick on this?
Thanks
-Steve
Old Sep 15, 2009 | 02:24 PM
Elton's Avatar
i got the tacoma whip at the junk yard for 10 dollars
Old Sep 15, 2009 | 02:43 PM
Fink's Avatar
Did you search on here for it?
Bob posted it a long time ago.
Fink
Old Sep 15, 2009 | 03:19 PM
scaesare's Avatar
Fink
I did, but if you look, the link in the thread you referred to is dead, but it appears that the link at the beginning of THIS thread IS Bob's writeup. That's the article I referring to where the issues are not clear (at least to me).
And in that thread yo ulinked to, there is some question as to if the antenna, and the antenna assembly is needed.
Also, I have a 3rd gen, and from the writeup posted in this thread, it's not clear if the part numbers are applicable.
Hence my questions.
Thanks.
Steve
Old Sep 15, 2009 | 03:21 PM
scaesare's Avatar
Thanks Elton. Did you just install it in place of a previous poer antenna unit in your '98? No other assembly needed? Is it a black antenna?
Thanks.
-Steve
Old Sep 15, 2009 | 03:51 PM
Fink's Avatar
Hence my questions.
Thanks.
Steve
I guess it helps to click the links before quoting them, huh?
Fink
Old Sep 15, 2009 | 05:23 PM
scaesare's Avatar
Fink
Hehe...
If you had seen it in the past, and you look at the link in post #1 of this thread, do you recall them a being the same?
Thanks.
-Steve
Old Sep 15, 2009 | 05:30 PM
Elton's Avatar
yes you will need the antenna assembly and the fender nut was a straight swap the antenna i got was black too if not nothing a little paint cant fix
Old Sep 15, 2009 | 05:31 PM
Fink's Avatar
Yes, it looks pretty similar.
He cleaned it up and put some new graphics in it but other than that they look the same.
I can't compare part numbers though, my memory isn't that good.
I did this mod on my '99 4Runner and it was very easy, I do remember that.
Fink
Old Sep 15, 2009 | 07:35 PM
scaesare's Avatar
Thanks guys.
-Steve
Old Oct 17, 2009 | 08:37 AM
Ron Helmuth's Avatar
I'm ready to do mine-I am glad for the link up.
I am glad to eliminate the drama associated with electric antenna. One of man's most useless inventions if you ask me.
Collapsible is fine-power collapsible is so unnecessary. That would be a cool design on a truck. The designers can make it happen for a sleek coupe into the A pillar....
always glad to stumble across the 2 year old threads and you guys supervising- this is so helpful to me-
really mean it- thanks for the guys like Bob98SR5 and 4x4Fink we don't go trashing our vehicles....
Old Sep 11, 2013 | 08:00 AM
nortonian's Avatar
Sorry to reopen an old thread, but will the same part numbers also work on a '95 2nd generation 4runner?
Old Sep 11, 2013 | 08:42 AM
MudHippy's Avatar
From the first link.
Thanks to UKMyers from Ultimateyota.com who provided the following part number for 2nd generation 4Runners:
Toyota Part # 86300-35070 (2nd gen 4Runners)
From the second link.
Originally Posted by Cebby
Here is the fixed antenna assembly part number for the 2nd Gen 4Runners: 86300-35070.
Try just a little harder next time there newb.
Old Sep 11, 2013 | 10:18 AM
nortonian's Avatar
Thanks old timer, but when I look that part number up its for a Power Antenna. The point of this thread is to replace the Power Antenna with a Whip antenna. Will the same whip antenna mount that is used in the mod for the third gen. 4runner work in a second gen?
Old Sep 11, 2013 | 10:58 AM
MudHippy's Avatar
It's not labeled correctly. The part # is for the fixed antenna assembly. Trust us. We're the ones who know better.
And no, it will not. Hence the different part # provided.
Old Sep 11, 2013 | 11:07 AM
nortonian's Avatar
Well then I'll take your word for it. But the $209.40 list price seemed kind of high for what you get.
http://www.midatlantictoyotaparts.co...na/86300-35070
Old Sep 11, 2013 | 12:02 PM
MudHippy's Avatar
Well, as it says, that would be for the entire assembly. Which looks to be 4 parts in total. PNC 86300.
PNC 86309B would be just the antenna mast/pole sub-assembly. That part # is 86309-32011.
You're lucky I happened to be here today to figure that one out for you. Odds are I'm THE ONLY member on this site who could have. Yes, I'm that badass at this.
As in...
No, IT'S NOT the correct part for a 3rd gen. 4Runner or Tacoma. Yes, IT IS the correct part for a 2nd gen. 4Runner.
