t case pops out of 4hi
Old Aug 28, 2007 | 07:30 PM
toby's toy's Avatar
I replaced the rear cover on my tcase. 87 pu 22r 5 spd. Since I put it back together it pops out of 4 hi when I let off the throttle or push in the clutch. Has anyone else had this problem or know how to fix it?
Old Aug 28, 2007 | 07:42 PM
DeathCougar's Avatar
You have a body lift? That or you put the shifter in backwards.
or in wrong
Old Aug 29, 2007 | 02:34 PM
toby's toy's Avatar
yes I have a body lift, no the shifter is not hitting the body. I'm guessing it is in wrong. I cut it to weld in a 3" extension, it worked fine for a while until it broke. It has only started doing this since I welded it back together. So I am thinking I am going to need a new shifter? Does anyone make longer ones for bodylifts?
Old Aug 29, 2007 | 04:08 PM
4Crawler's Avatar
Make sure you did not stab the shifter in 180 degrees out. And pull the shifter boot and see if that makes any difference. If so, see:
- http://www.4crawler.com/4x4/ForSale/...l#ManualTranny
Here is an option for a body lift:
- http://www.4crawler.com/4x4/ForSale/...wShifter.shtml
Old Aug 31, 2007 | 07:18 PM
toby's toy's Avatar
Ok I replaced the shifter, it still will not stay in 4 hi, I even put it in 4 hi pulled the shifter out and it still jumps out of 4 hi. I am guessing it is something internal, it will stay in 4 lo. Also when jumps out of 4 hi I have to pull the shifter to get it back into 4 hi or 2hi. Does anyone have any ideas? Shifter bushing?
Old Aug 31, 2007 | 07:20 PM
4Crawler's Avatar
Might try a heavy duty shift spring from Marlin Crawler:
- http://www.marlincrawler.com/htm/tra...e/tcase_ac.htm
Old Aug 31, 2007 | 09:15 PM
Elvota's Avatar
I installed those Marlin HD springs in my transfer cases and it was like night and day. Real positive engagement now.
Might be worth a shot to fix your issue.
Old Sep 1, 2007 | 03:51 PM
toby's toy's Avatar
yeah I was checking out their site, and was thinking about trying it to see if they fix it. Should I replace only one , or both of them?
Old Sep 1, 2007 | 07:06 PM
Elvota's Avatar
I had heard they where next to impossible to replace with the transfer case still in the vehicle. I got lucky and managed to swap them, transfer still in place.
If I was going to do all the work to swap one, I'd probably just swap both if I had access. Couldn't hurt.
Old Sep 1, 2007 | 07:19 PM
4Crawler's Avatar
My buddy had the same experience on his '94 pickup. 1" body lift helped a little. The springs are behind allen screw caps on the top edge of the t-case (in line with the internal shift rails), so pretty tight quarters to work in w/ t-case installed. Might help to un-bolt the crossmember from the frame and lower the back of the drivetrain a few inches for more working room.
Old Sep 2, 2007 | 06:27 PM
toby's toy's Avatar
Is there supposed to be a spring on each side of the t case? I only found a screw on the pass side. If there is supposed to be one on the drivers side it is missing, there is a threaded hole on the drivers side but no screw, so therefore no spring and no ball bearing ?
Old Sep 2, 2007 | 07:47 PM
toby's toy's Avatar
okay, I'm an idiot. Both screws and springs are there. There is a hole forward of the rear spring screw on the drivers side, which I thought was for the spring ball assembly. Looks like I will be ordering the heavy duty springs. Thanks for all your input.
Toby
Old Sep 8, 2007 | 07:53 PM
toby's toy's Avatar
okay I put the springs in, no more popping out of 4 hi. BTW they went in no problem with the 3" bodylift.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
Daenerysdad
Oct 1, 2015 07:33 PM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
eggens
Sep 5, 2015 12:16 AM
