Synthetic Oil
Old Sep 3, 2006 | 12:07 PM
darkglass's Avatar
Synthetic Oil
My 98 Runner 3.4 has 117k on it. The previous owner ran 5w 30 oils. I would like to run synthetic Mobil 1. Is it too late to switch?
Old Sep 3, 2006 | 12:40 PM
seanz0rz's Avatar
Guest
there was a thread on this a few days ago, search for synthetic oil.
i just dumped 5.5 quarts into mine, mobil 1 7500. ill get the engine, which as always run on dino as far as i can tell, started on the 7500 stuff. next oil change ill decide to keep or move to the 15k stuff. seems like when i need an oil change, i can NEVER find the time to take it in or do it myself (never taking my vechile in unless i HAVE TO)
Old Sep 3, 2006 | 01:06 PM
X-AWDriver's Avatar
I'm sure you'll be fine switching over. I switched at 98k two years ago and now I'm at 118k and mine doesn't even burn a drop inbetween it's 9000 mile interval.
Old Sep 3, 2006 | 01:19 PM
Potomacduck's Avatar
I bought my '99 Limited at 150,000 with documented dealership maintenance. I switched over to Mobil 1 5W-30 every 5,000 miles with the factory filter.
That was 35,000 miles ago. It runs great, never leaks, never burns a drop of oil and gets 19-20 mpg on the highway.
Old Sep 4, 2006 | 07:38 AM
AK's Avatar
AK
I switched my 1996 over to amsoil 5w-30 when i had 129,000 on it. I now have 139,000 and have no leaks or any problems.
Old Sep 4, 2006 | 06:08 PM
Toyopnoy's Avatar
Never to late IMO. I switched my 86 4Runner to Amsoil at 168000 miles and it still runs pretty strong. All original equipment might I add and now it's at 176000. Just make sure you change the oil filter after 1000 miles from the switchover. The synthetic will free up a lot of the detergents left behind from regular oil and the filter will get dirty pretty fast.
Old Sep 5, 2006 | 10:14 AM
jjrgr21's Avatar
does anyone know how the different oils are ranked, by research, if so where does mobil1 rank. cheap at costco
Old Sep 5, 2006 | 10:19 AM
Localmotion's Avatar
do a search brotha....mobil 1 is good stuff
Amsoil is also very good. They make a oil that you change once a year.
Old Sep 5, 2006 | 04:49 PM
helidriver's Avatar
I've always leaned towards valvoline. No reason just picked one and stuck to it. Anybody know anything not to use valvoline?
Old Sep 5, 2006 | 05:00 PM
surf4runner's Avatar
i was unsure about switching at 90k, so i used synth blend first and have been using full synth since. @ 119k & no problems at all.
Old Sep 5, 2006 | 05:13 PM
crackerjack's Avatar
Yeah I'm kinda eeeasin in to synthetic by going blend first.I never was the type that ran screaming and dived into the swimming hole.
Old Sep 9, 2006 | 03:15 PM
youngbuck's Avatar
I would auto-rx it first:
www.auto-rx.com
It's what I did with mine.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Toyvana
Jul 29, 2015 10:47 PM
yourrealdad
Jul 29, 2015 11:08 AM
irritech
Jul 27, 2015 05:15 PM
calderp
Jul 27, 2015 09:58 AM
