Suspension & Axle Questions
Old Jul 21, 2008 | 07:24 AM
83's Avatar
83
First off, I replaced my shocks over the weekend. The bolt on top of the front shock can be tightened way down, to the point where the rubber washers are bulging way out. How tight should it be? I'm afraid tightening it too much will cause some premature cracking of the rubber, but obviously I want it tight.
Also, did the PO of this truck put some armor on my front axle, or is this how '79-83 axles look?
Old Jul 21, 2008 | 07:36 AM
dirtoyboy's Avatar
The gusset on the bottom is stock...
Use a locking nut and tighten the nut down until its tight
Old Jul 21, 2008 | 08:02 AM
83's Avatar
83
Would the nut that came with the shocks be a locking nut? They are Bilstiens. The nut is just keeps going down farther and farther, and the rubber is bulging out more & more.
Old Jul 21, 2008 | 08:19 AM
dirtoyboy's Avatar
Dunno..probably...it should be a locking nut on there
a nylon locking nut has a nylon insert in it...
Are you able to unthread the nut by hand? Tighten it down until the rubber starts to bulge and leave it...the torque is not all that important
Old Jul 21, 2008 | 08:30 AM
83's Avatar
83
Thank you. Yes, it has a nylon insert, I was wondering what the deal was with that. No way I could unthread it by hand. I think I'll back it off a little, I've probably got it too tight. Thanks!
Old Jul 21, 2008 | 10:55 AM
dirtoyboy's Avatar
You got it buddy!
Old Jul 25, 2008 | 03:49 PM
20twinz's Avatar
Did you do this or was it a pic you found? Is that steering Stablizer have the braket coming off the axle? That work well? I have duels on mine and dont like how they are fasend. Would rather see them attateched to the axle if it works well that way.
Old Jul 25, 2008 | 06:29 PM
jvmin's Avatar
my shocks came with a small steel sleeve that fits over the bolt and inside the rubber bushing that lets you tighten it all the way tight. but they also came with several sized bushings and sleeves to fit multiple applications.
Old Jul 28, 2008 | 06:09 AM
83's Avatar
83
Yeah, that's a picture of my truck. The steering stabilizer is attached to the stock (I think) location on the axle. They did a little modifying on the other end of it, but it's still attached to the stock location, just with some extra bracketry..don't really know if it works "well"...this is my first solid front suspension truck so I don't have much to compare it to.
Old Jul 28, 2008 | 07:35 PM
20twinz's Avatar
Cool, thanks for the info.
Old Jul 28, 2008 | 07:49 PM
algranger's Avatar
looks like an 84/85 axle
Old Jul 29, 2008 | 06:19 AM
83's Avatar
83
Really? That would be interesting to know, since it's an '83. My experience is mostly with the '86-88 trucks, so I don't know all the little things to look for on the early '80s ones.
Old Jul 29, 2008 | 06:43 AM
dirtoyboy's Avatar
That is definitely an 81-83......gusset goes to the u-bolts. 84-85 has the gusset all the way past the ubolts like this>>
Old Jul 29, 2008 | 07:56 AM
83's Avatar
83
Great, thanks.
oldirtydirt
Feb 23, 2020 09:30 AM
polo451
13
Nov 20, 2016 07:49 PM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
coffey50
Jul 28, 2015 10:55 AM
Vargntucson
Jul 4, 2015 12:15 PM
