stainless steel strength ???
Old Feb 15, 2010 | 03:36 PM
swerks's Avatar
Are stainless steel bolts strong enough to hold my Turbo to the exhaust manifold ? I know they're no grade 8. this is a difficult size bolt, that is why I'm considering it.
Old Feb 15, 2010 | 04:00 PM
xjdubber's Avatar
why would you even need grade 8 bolts? its just a turbo, what makes you think that you even need grade 8?
Edit: you'd probably want the bolt to be the same material as what you're bolting to so it expands and contracts the same rate.
Old Feb 15, 2010 | 04:06 PM
kiyobrown's Avatar
Look up Tacoma Screw. They Have all the hard to find sizes and pitches. Some things, like pressed on washers, they don't have though. Dealer only. I guess J yard, too
Old Feb 15, 2010 | 04:14 PM
swerks's Avatar
Im not saying I need grade 8. I just want to know that SS is enough for that application.
Old Feb 15, 2010 | 04:32 PM
xjdubber's Avatar
http://www.boltdepot.com/fastener-in...ade-Chart.aspx
look at the chart and make your decision i would bolt on a turbo with any bolt i could find in my folgers coffee tin.
Old Feb 15, 2010 | 07:45 PM
tc's Avatar
tc
Yes, stainless would be strong enough, but the problem will be that there's no antiseize that will survive at that temp, resulting in galvanic corrosion making the bolt unremovable.
Fastenal will have or can order whatever size you need.
kawazx636
Oct 6, 2021 03:03 PM
Obmi
Oct 4, 2015 11:30 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
Gravel Maker
RuffStuff
Sep 8, 2015 05:46 AM
mirabile4runner
Sep 3, 2015 07:15 AM
