Spray paint or buy a gun?
Old Mar 24, 2009 | 02:00 PM
874runnersr5's Avatar
ah wow thats alot of info, thanks man
Old Mar 24, 2009 | 04:22 PM
wheatus's Avatar
check out a thread titled $150 paint job for tips on preping for paint. any questions just ask.
Old Mar 24, 2009 | 06:34 PM
is it that hard thoe?
the only thing that worries me now is the air compressor, and all that other stuff.
Old Mar 24, 2009 | 06:54 PM
wheatus's Avatar
it isn't hard but like any other skill it takes a lot of practice to master. on top of that there are many things that can cause problems. the good thing is that you will get to practice on the inside of the door first but before you get to that are you going to repair anything on the door? if so you need to do your repairs first. the easiest thing to do is take all of the guts out of the door so you dont have as much to mask. get some red scuff pads and scuff it all really well, anything shiny is bad. at this point you will be ready to clean it up and mask it for paint. while it is not necessary to mask, it makes prepping the outside of the door much easier. you will need some wax and grease remover to wipe before you spray and you can also use a mixture of alcohol and water to keep static down and to get any remaining dust. if the outside of the door is in good shape you can sand with 400-600 grit sand paper or you could just use the scratch pads. on exterior panels it is essential to get all of the edges and grooves really well as this is where most paint jobs start to peel. as for paint i would first try local body shops and try to beg some scraps. auto paint is haz mat so they might be glad to give some away. i would use the same manufacturer for base coat and clear coat. if you take your time you can get good results. the only thing that would concern me is the size of your compressor but you will have a better idea when you spray the inside of the door.
Old Mar 24, 2009 | 07:03 PM
  #25
bigt's Avatar
im gonna use my gun once i weld in floors rockers fenders in my suzuki...
i have a bit bigger comp i think tis 3.5 or so horse with a 15 gallon tank... its a long one on wheels ..
what prepssure do you set at?? 100 like power tools?
Old Mar 24, 2009 | 07:08 PM
  #26
wheatus's Avatar
not even close if you got the HVLP it is like 8-10
with all of the questions people have about paint i was thinking about doing a how-to. anybody interested?
Old Mar 24, 2009 | 07:20 PM
  #27
yes!
please do
Old Mar 24, 2009 | 07:42 PM
  #28
Ed H.'s Avatar
consider a air/water separator for your compressor if you are going to run your compressor alot you will get some water in your line which is especially bad for painting they are not very expensive you can get them at harbor freight. its not a bad idea to have one anyways. here is a link to the first one i found on google http://yhst-13185147461285.stores.ya...airwatsep.html
Old Mar 24, 2009 | 07:49 PM
  #29
damn i want to find one of those locally
Old Mar 24, 2009 | 07:53 PM
  #30
Ed H.'s Avatar
anywhere that sells compressors should have one, home depot, lowes, napa, body shop supply stores and hardware stores they are easy to find.
Old Mar 24, 2009 | 07:54 PM
  #31
toyospearo's Avatar
buy a gun, preferably a SATA... and a good compressor 12 cfm at 90 psi or higher or forget it.
git r done!
Old Mar 24, 2009 | 07:55 PM
  #32
arent the hvlp the best tho?
Old Mar 24, 2009 | 07:57 PM
  #33
aight cool, i look into them
Old Mar 24, 2009 | 08:04 PM
  #34
toyospearo's Avatar
Yes HPLV are the best and in IMHO SATA makes the best gun hands down! As far as a "watertrap" just put it between the hose and the gun and go to town
Old Mar 25, 2009 | 05:30 AM
  #35
sweet thanks spearo
Old Apr 12, 2009 | 04:48 PM
  #36
wheatus's Avatar
it is not that the HVLPs are the best they are just the most efficient, less material lost as overspray. SATAs are excellent guns but unless you are willing to shell out $300 bucks or more forget it. be very wary of buying used guns because they most likely need a rebuild. rebuild kits for these guns are expensive as well, if i recall correctly it was $80 bucks or better. iwata makes a great gun and devilbiss makes some good ones as well. one of the best shop water filters i have ever seen uses a roll of toilet paper in a housing when they get wet just pitch and replace. the ones that mount on the gun are better than nothing. when do you plan on painting?
Old Apr 12, 2009 | 05:28 PM
  #37
bigt's Avatar
prnicess auto is the best place in canada to get the water seperator and any air tool parts.. the power fist is cheap but good for one offs!!
Old Apr 13, 2009 | 08:18 AM
  #38
Hm thanks for the info, i went to this local paint shop and they told me that they will be getting these kits in within a month or so. Little kits just enough to do fenders/hoods..ect..
so ill try to get it done next month
chukarhunt
Dec 8, 2019 11:39 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
Regency
Sep 4, 2015 01:32 PM
58rennur4
Aug 4, 2015 08:49 AM
