Silla all aluminum radiator?
Old Dec 2, 2009 | 05:49 PM
forwardtocharis's Avatar
My radiotor keeps developing spontanious leaks soI figured I'd put a new one in this winter when I rebuild my engine.
So I came accross this Silla all aluminum radiator (tanks & cores) for only $170 w/ lifetime warrenty. Anyone heard anything about these?
http://www.autopartswarehouse.com/de...85c7ab9e&gan=1
Sill Radiatorhttp://www.autopartswarehouse.com/de...85c7ab9e&gan=1
Old Dec 2, 2009 | 06:54 PM
firemaniac's Avatar
I just bought a new radiator from Performance Radiators and was going to get an Aluminium radiator but after talking to theme I decided to go with copper/brass, for the simple reason that Aluminium/plastic radiators are glued together, and if anything but proper (distiled water, and coolant) are used there is a potential to degrade the glue, copper/brass is more forgiving if you have to do some McGuivering on the trail.
Old Dec 2, 2009 | 07:34 PM
ya.. that's why i was asking about an ALL Aluminum radiator - no plastic tanks
Old Dec 2, 2009 | 09:21 PM
GO_BLUE!'s Avatar
I just had an aluminum radiator installed in my '92 Runner (3.0) today. It replaced the old (ORIGINAL!) radiator. I only have 113,550 miles on her (really!), but I went with aluminum as it is cheaper, lighter, and compatible with Toyota Red coolant.
I just spent the last 48hrs. reading about coolants, radiators, etc... and I'm going with an aluminum radiator due to the cost/weight and Toyota Red coolant to help preserve the iron engine block. Red (supposedly) does a better job preserving iron then Green coolant. Red Toyota coolant retails for $20-$26 bucks!
But I dunno... there is a used 4Runner radiator on craigslist here in the Bay area for $50... I might just go buy it in case I want to switch back to the original brass/copper/metal radiator with lead soldering. But I'ma gonna give the aluminum one a chance first.
Required Reading: https://www.yotatech.com/forums/f116...nt-faq-192781/
-Tom
Old Dec 2, 2009 | 10:04 PM
Thanks for the info, I hadn't read any of that about the coolant before, good to know. I've always been running green :/
I'm thinking about either:
This one from ebay
-OR-
Or this one from Silla
with: Zinc Anode Kit
Plus I'll probably use some isolating bushings to keep the radiator from going to ground to further decrease any chance of electrolysis and I might look into some water-less coolant. I know that if I used distilled water it won't conduct, but with it coming in contact with iron, steel and aluminum at both cold and hot temperatures I can't help but imagine that the distilled water will slowly take on conductive properties. If I'm flat out wrong about this please let me know.
ladybugRC
458
Aug 21, 2020 10:41 AM
4x4YOTA
Aug 23, 2016 09:08 AM
mreagen
Oct 5, 2015 04:27 PM
scott90
Oct 4, 2015 09:21 AM
Matthew Perez
Sep 28, 2015 05:43 PM
