Shock length for 2inch lift
Old 10-04-2016, 12:47 PM
ThatOneMurse's Avatar
Recently bought a 94 pickup with a 2inch lift. Shocks they had on it are pretty worn out so looking to upgrade. Thinking kyb monomax since i can get a set on rockauto.com for $220 shipped. anyone have recommendations on length for these? I see a lot of shocks rated for stock suspension but it's hit or miss finding something for a truck with a lift. Any suggestions and advice is greatly appreciated. I attached a picture of the truck as well Thanks
Old 10-04-2016, 01:43 PM
MaK92-4RnR's Avatar
Just get some RS500s. I'm assuming it's just got the BJ spacers with a block or shackle in the rear?
Here's the part # to the rancho shocks:RS5167
Old 10-04-2016, 02:27 PM
everything I found on that part number says it's for a Suzuki Samurai? Also I've heard bad things about rancho shocks
Old 10-04-2016, 02:44 PM
muddpigg's Avatar
You measure distance between to shock mount with bottom shock mount at both full compression and full droop. Figure out mount shock mount style. Use whatever brand shock you want to run's catalog to select part number and order from favorite vendor.
If you know old whocks are correct size. Use whatever brand shock you want to run's catalog to select part number and order from favorite vendor.
or pick a brand of shocks that caters to matching vehicle to lift height and part number. Order those shocks from favorite vendor.
Old 10-04-2016, 08:25 PM
Robert m's Avatar
Unless the shock mounts were moved or modified in the front, you only need stock length shocks. Longer ones will probably bottom out before full suspension compression is reached.
E-ROC
07-16-2017 02:00 PM
4Nmissile
11-14-2016 08:54 AM
Allmyjunk
09-01-2016 11:16 AM
Allmyjunk
08-01-2016 05:38 PM
rustypigeon
07-28-2016 06:16 AM
Quick Reply: Shock length for 2inch lift
