seafoam
Old Dec 29, 2007 | 05:45 PM
camo31_10.50's Avatar
seafoam
just ran the seafoam through my truck..(1980 yota 4x4 20R)..and it didnt seem like it did a damn thing...it kinda made it idle a little bit better...but not much...i just put it in the carb...is there anywhere else i should put it (i.e. crankcase gas tank...anywhere)...didnt smoke hardly any...i figured it would smoke like B@#$#...but it didnt...any info would be helpful....thanks
Ken,
Old Dec 29, 2007 | 06:14 PM
linuxrunner's Avatar
How long did you let it sit before you started it back up again?
Old Dec 29, 2007 | 06:16 PM
fork's Avatar
x2
Old Dec 29, 2007 | 06:59 PM
the first time i did it...i let it set right at 6 mins...the second time i did it..it sat prob close to 10..did i not let it sit long enough....
Old Dec 30, 2007 | 02:38 PM
Adam F's Avatar
how much did you suck up
Old Dec 30, 2007 | 02:55 PM
infiltrator's Avatar
let it sit an hour and see what happens.
put it in the gastank
Old Jan 2, 2008 | 08:46 AM
mkgarrison5's Avatar
this is what i do and i know this works very very well from past experience.
2 can of seafoam in the tank with 4-6 gallons of fuel to mix, run till almost empty
then take 1 can and in 1/3 increments suck it up via the pcv valve or brake booster and let it the first sit for 15 mins, 2nd for 30 mins and the last of it leave in there all night.. burn it out when you drive to work in the am..
change the oil after all of this too. most fuel cleaners leave residue and lots of additive mess in the oil so change it a day or so after you do this.
urabus
Nov 10, 2015 07:38 PM
sanctfy
Sep 13, 2015 06:33 PM
Boomer8404
Sep 10, 2015 09:01 AM
accuracy
Aug 4, 2015 08:05 PM
jjccamis
Jul 9, 2015 04:00 PM
