removing elocker connector-help!
Hi,
I'm removing the third member from a tacoma trd and I can't get the pass. side connector off of the elocker actuator. It is square gray plastic and I don't see a tab on it. Sorry I don't have a digital camera. Also, I didn't lock my locker before removing the third; Do I need to lock it or can it be locked manually once I remove it? Thanks!
Hornito
Hornito
Look close again, IIRC there is a tab that needs to be un clipped. The connector has an "O" ring seal and has a dab of grease from the factory, makes for a tight suction fit.
No worries on removing the 3rd unlocked, you might have to lock it to get it back in, some times the locking collar likes to get hung up on the axle housing, makes it a bear when trying to hold it up and get it lined up
Got a question.
Does anybody sell a manual cable for the e-locker third ?
I am planning on adding the e-locker and would prefer to operate it by cable
instead of the inch worm wiring kit.
1uzRunner
63
Nov 10, 2018 03:58 PM
LotOMiles
Sep 14, 2015 11:45 PM
Rickstwowheels
Sep 9, 2015 06:12 PM
must be seized on there?
