Recomend me a POR-15 type paint avalible at retail stores ASAP!
Old Aug 23, 2006 | 07:53 PM
4x4Lamm's Avatar
So I am in the process or removing ALL the paint and powdercoating from my TJM bumper and repainting the same way I did my sliders.
-I used chemical stripper and wire wheels to remove all the paint and powdercoating (I hate powdercoating)
-I used POR-15 metal ready on the rust
-I used 5 cans or Duplicolor self etching primer
Here is the roadblock, the next step is a brushed on coat of POR-15.
Even though I orderd the paint last week as far as I know it has not even shipped yet. I will call them tomorow and unless it is going to be here by Friday I will just cancel the order. I need a backup paint though.
What product (avalible at retail stores as I have never seen POR-15 in a shop) is of like composition, application, use and quality?
I cannot wait forever for the POR-15 to arrive so I can finish and have my 4Runner on the road again so I just need recomendations on the best alternitive that I can get my hands on fast.
A product and store suggestion from you would be great, the more detail the better.
Thanks so much!
Lamm
Old Aug 23, 2006 | 08:08 PM
Cebby's Avatar
I have a sixpack of smalll cans I can send you if you replace mine - just pay my shipping to you and replace them when yours come in. If I send tomorrow you should have them Friday or Sat at the latest.
Old Aug 23, 2006 | 08:15 PM
4x4Lamm's Avatar
Cebby, thanks so much. Before you go to work tomorow check your PM. If nobody comes up with a better solution I will have you do that and I will refund you for the cost of the overnight shipping (at this point money is no object) and order a new 6 pack and just have it shipped to your place.
Thanks again!
Lamm
Old Aug 23, 2006 | 08:23 PM
Cebby's Avatar
It's been a while since I looked at it. It's actually 3 cans of POR15 and 3 cans of their special chassis paint.
Pics in a sec or two...
Old Aug 23, 2006 | 08:25 PM
Cebby's Avatar
I just hope it's enough for you - the cans are pretty small... I'll check back in the AM...
Old Aug 23, 2006 | 08:26 PM
4x4Lamm's Avatar
That is fine as well, 3 cans is plenty, thanks again.
Lamm
Old Aug 23, 2006 | 08:46 PM
dwh91102's Avatar
Imo por15 is overkill for something that hasn't started to rust. What exactly are you looking for out of the paint?
Old Aug 23, 2006 | 08:56 PM
4x4Lamm's Avatar
But it has rusted in spots.
I like the POR-15 because it forms a single, tough, flexable layer of protection that does not let water in between it and the metal when it gets scratched (like powdercoating).
Lamm
Old Aug 23, 2006 | 09:17 PM
dwh91102's Avatar
All ok I wasn't under the impression that it had rusted. I don't really know of anything else out there like por, there are several products that rust inhibitors.
Old Aug 23, 2006 | 09:21 PM
4x4Lamm's Avatar
I am resaerching a product called Valspor right now, it is avalible at TSC.
I will be undercoating most of the inside of the bumper (100000000 times better than POR-15) and the outside can be touched up untill I have time to do it all again if necessary I suppose, uhhhhh.
As gracious as Cebby is I would like to stay on schedula and not have to call of work on Sat. Who knows, it may be the only option.
Lamm
Old Aug 24, 2006 | 05:16 AM
Cebby's Avatar
Lamm - what did you figure out? I think I can send out until 5pm or so at Staples (via UPS Red) and you'll have it tomorrow... Let me know.
Old Aug 24, 2006 | 07:29 AM
spdjnky's Avatar
I have some Jasco prep and primer that a guy let me have to try out. He said you can get it at Lowe's or Home Depot. Check out the webstie..
http://www.jasco-help.com/products/prod_mg.htm
If you use this let me know how it works. I have not had the time to try it out.
Old Aug 29, 2006 | 03:05 PM
Snorkeldepth's Avatar
IIRC doesn't the POR-15 need to be in direct contact with the metal? By priming with the Duplicolor and topcoating with POR-15 don't you insulate the metal from the protective effect of the POR-15? I think the POR people recommend priming and topcoating over POR-15 if you want a particular finish.
I checked the online directions . . . (http://www.por15.com/Portals/0/uploa...directions.pdf), which say that POR-15 should not be applied over other paints.
I don't want you to waste any of that very expensive paint!!!
Look at this too, http://www.por15.com/Portals/0/uploa...cationInfo.pdf. Note the section on "What is "Proper Preparation?"" that says that if POR-15 is applied over another coating it will not provide long term rust protection.
I used the "Marine Clean" and "Metal Ready" under my battery before applying POR-15. The only other thing I learned in the process is to make sure that there's no moisture remaining on the surface you are painting. There are some joints where the stock battery mount is spot welded to the inner fender that held moisture and required some touch up work because the POR-15 bubbled.
Old Aug 29, 2006 | 03:33 PM
4Crawler's Avatar
I just ordered some POR-15 late yesterday and received a shipping notification e-mail today, so they normally ship ASAP.
Yes, best to apply over bare (or rusted) steel, but over other paint, I usually find that it ends up making an excellent "paint stripper" As the underlying paint fails, the tougher POR-15 will lift the old paint off the steel if it gets scraped, leaving bare metal underneath. If you can at least deeply scratch the old paint through to steel, it may work OK. Probably skip the primer coat and just use a top coat in that case. And I like to get the bare steel rusty before painting, thin surface rust helps to roughen up the steel for the paint to stick better. Either use some sort of acid (phosphoric acic, CLS, Lime-Away) or even a spray of salt water to flash the surface w/ rust, or leave the steel exposed to air for a month or so.
Old Aug 29, 2006 | 04:26 PM
swerks's Avatar
any one use rust bullet ?????
Old Aug 29, 2006 | 06:45 PM
4x4Lamm's Avatar
When I called the POR-15 people thay looked up my order numbe and said, whoops, sorry, we will get it right out. I dais how long? It was too long so I canceled the order.
I know what the POR-15 website says, I also know what I have done in the past on many metal things works just how I want it to.
Lamm
Old Aug 29, 2006 | 07:02 PM
Lamm
Cool! Just making sure.
Old Aug 29, 2006 | 07:04 PM
4x4Lamm's Avatar
Yeah, I don't really use it for the metal to paint adhesion, just as a strong, chip resistant coat between the primer and paint.
Lamm
Old Aug 29, 2006 | 07:05 PM
CyMoN's Avatar
i have been testing and using NAPAs rust to black by just applying it to rusted metal and not painting it for a few months to see if it really works or if it will rust through
Old Aug 29, 2006 | 07:08 PM
metal to pain adhesion
Now, I'm starting to worry! But, then again you're one of those rescue paramedic guys right?
Don't forget the pictures when you're done!
