Receiver Hitch Shackle vs. Hook?
Old Nov 28, 2007 | 03:20 AM
nick_8787's Avatar
I'm debating whether or not to get a receiver hitch shackle or hook. What are some thoughts on pros or cons for either. Any reasons why one be better than the other? i.e. is one generally thought to be stronger or more secure than the other?
Old Nov 28, 2007 | 08:07 AM
Tacoclimber's Avatar
Well, while I can't give a rundown on the physics of the whole thing, just looking at the difference between the two, if you had to use one for recovery, do you want to use something that is open on one side, or something that is completely closed and will distribute the dynamic force being applied to it? I know some guys use hooks, but I feel safer using shackles. There is a reason why some off road clubs won't even let you on trail runs without having at least a couple of them.
Old Nov 28, 2007 | 08:14 AM
tc's Avatar
tc
I have both.
the shackle is nice in that the strap can't fall off
the hook is nice in that you can put the strap on and off a lot easier
Both are rated at similar capacities, more limited by the hitch pin holding the device in the receiver than the device itself.
Old Nov 28, 2007 | 08:38 AM
I just screwed my shackles to my tailgate. Will that be a problem?
Old Nov 28, 2007 | 09:37 AM
jagger_snitt's Avatar
I believe that the shackle would be safer and better. That hook won't work at nearly any angle of recovery. You can't always be pulled straight out,and because of the angles I would choose the shackle,you also don't have to worry about the rope coming off. All you have to worry about is breaking the shackle,winch line,or tow rope. The shackle would probably be the least likely to break. Hope this helps.
Old Nov 28, 2007 | 11:55 AM
nick_8787's Avatar
I had similar thoughts on the matter. Thanks all. I shall purchase a shackle.
ashamsuddin
17
Jul 22, 2024 03:59 AM
Steven.m.paulk
Jun 7, 2020 10:45 AM
smilen724
13
Nov 8, 2015 04:11 PM
bryan34w
12
Sep 30, 2015 02:50 PM
oldblue
Sep 28, 2015 04:07 PM
