radiator problems
Old Nov 10, 2009 | 05:34 PM
hollandridgely's Avatar
radiator problems
so i have a radiator leak on my 91 4runner. as far as i can tell it is isolated to the pipe that the upper hose is connected to. the repair shop wants $50 fix it, if it is a copper/brass radiator.
what is the easiest way to tell if it is a copper/brass or aluminum/plastic? they are both painted the same. or is it even worth messing with?
Old Nov 10, 2009 | 05:37 PM
4Crawler's Avatar
Scrape the paint a little on the tank. If it is copper/brass there will be a yellow metallic surface under the paint. If plastic, it'll just be black all the way though. Or tap on it with something metal, the difference in plastic vs. metal should be apparent.
Old Nov 10, 2009 | 05:43 PM
thanks a ton
Old Nov 10, 2009 | 07:56 PM
Adam F's Avatar
I've soldered leaky radiator necks with a blow torch, flux, and solder before. Try it if you have the supplies.
Old Nov 11, 2009 | 05:39 PM
that's a good idea... i was thinking of doing that, but i don't have that much experience eventhough i have the stuff. would i have to pull the neck out to put the flux on or is there an easier way?
Old Nov 14, 2009 | 05:02 PM
so the solder idea worked great thanks
the1998sr5
15
Jul 14, 2020 08:35 PM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
the1998sr5
Jul 16, 2015 06:20 AM
Poncho0206
Jul 10, 2015 06:21 PM
Avenged
Jul 9, 2015 07:55 AM
