Question on gear ratios, School project
Old Mar 14, 2006 | 02:11 PM
paintball11090's Avatar
Ok guys im doin a project for algebra 2. I have to type a one page paper on something involving math and I chose to do the gear ratios on my '94 4runner. I need to know where to look for the gear ratios of my truck and what they mean. I dont know what ratio I have in my rear end but im thinking its a 4.11 or a 4.84 or whatever. I also need to know the ratios for the trany(probly just 1st gear) i have a 5 speed, and the t case (4 lo and hi). Any info would be greatly appreaciated.
Thanks,
Greg
Old Mar 14, 2006 | 02:30 PM
wjwerdna's Avatar
I typed "STOCK GEAR RATIOS" into (sorry just wanted to use that , thanks to Midiwall) and found this in about 5 min
https://www.yotatech.com/forums/show...ck+gear+ratios
Originally Posted by regularguy412
Look on the plackard inside the lower part of the driver's side door jamb ( near the B pillar ). It should have tire size information listed there, as well as some codes that tell what the stock transmission is, as well as a code for determining differential gear ratios.
this may help find what tranny and such you have
http://www.4x4wire.com/toyota/faq/parts/
theres a lotta good stuff here
https://www.yotatech.com/forums/show...on+gear+ratios
http://www.ramblerman.com/blazer/gearcalc.htm
http://www.off-road.com/toyota/tech/other/4_axles.html
and heres more good stuff once you find what tranny you have
http://www.off-road.com/toyota/tech/other/4_dts.html
I hope that gets you on the right track... - Andrew
Old Mar 14, 2006 | 03:03 PM
Thanks alot man i only had time to search like one page cause I got this projet and a 6 page english project due next week. BTW that search is sweet. I knew I could count on yotatech
Old Mar 14, 2006 | 03:05 PM
wjwerdna's Avatar
no prob ... heres something I've heard too much "when were they assigned???" lol, good luck, you've got about 5-6 days before you really need to start on the papers
88sasturbotoy
Jan 30, 2026 01:57 PM
bigjstang
Jun 2, 2025 03:56 PM
oldirtydirt
Feb 23, 2020 09:30 AM
jasonty
41
Dec 23, 2018 01:00 PM
Jnkml
Jul 6, 2015 01:20 PM
