question about toyota years
Old Aug 17, 2010 | 05:02 PM
desertfreeek's Avatar
I was wondering what the last year toyota made a 4x4. 4cly. single cab. with 5 speed? Anyone know?
Old Aug 17, 2010 | 05:10 PM
toyota4x4907's Avatar
2nd gen Tacomas ('05-current) can be had in 4cyl, 4x4, single cab, 5/6spd manual configuration...
...so basically they havent stopped producing them...
Old Aug 17, 2010 | 05:16 PM
tj884Rdlx's Avatar
they've always made them.
you can buy a 2011 Tacoma 4x4 single cab with 2.7 inline 4 cyl. with 5-speed right now, for about $21k
what color would you like?
in fact, if you go to http://www.toyota.com and click the "build your own" link, you can put in your zip code, build the truck exactly how you want, and it will tell you where the toyota dealers are that have one just like it.
Old Aug 17, 2010 | 05:17 PM
brian2sun's Avatar
I could be wrong, but I think the standard cab, 4x4, 4 banger will not be available in 2011. I tried building one on Toyota.com the other day and it wouldn't let me choose those options.
Old Aug 17, 2010 | 05:19 PM
bmxmike's Avatar
actual 4x4 u mean solid axel front stock...it was 1985 and earlier
Old Aug 17, 2010 | 05:22 PM
PismoJoe's Avatar
woah there bud so my IFS isn't 'actually' 4WD??
Old Aug 17, 2010 | 05:23 PM
correction. if its a 4x4 solid axle he wants then its '79-'85. Toyota didnt make minis in 4x4 until '79.
Old Aug 17, 2010 | 05:32 PM
brian2sun's Avatar
Having a front diff and a t-case determines if it's 4x4, not a solid axle.
Old Aug 17, 2010 | 05:35 PM
scuba's Avatar
It's cause your zip code. Try putting in a zip from back east and it'll let you build a 4x4 single cab 5 speed 4cylinder Tacoma.
So like said, since 1979 Toyota has always made that configuration. They'd be fools to stop that too
Old Aug 17, 2010 | 05:36 PM
tj884Rdlx's Avatar
nah, i was just there messing with the build your own. its model 7503 for 2011.
well, i AM in the east, so i guess that's why i had no problem. good eye, scoob.
that is a fact.
took the words write outta my mouth.
Last edited by tj884Rdlx; Aug 17, 2010 at 05:43 PM. Reason: to avoid making 4 different posts for the same conversation
Old Aug 17, 2010 | 05:45 PM
brian2sun's Avatar
Ahh. That's lame. What do they have against us? It's not like it has a pistol grip and a detachable magazine!
Old Aug 17, 2010 | 07:51 PM
thanks
i should have looked first
Old Aug 17, 2010 | 07:55 PM
I just went to the build your toyota wed site. It would not let me build it with a standard trans.
Old Aug 17, 2010 | 07:58 PM
I want a newer salvage title truck to put a strait axle under it. So i can crawl it. That would be bad.
Old Aug 17, 2010 | 08:07 PM
clydehatchet's Avatar
you can still get a standard if its not SR5 or v6. but thats only online. i have to wonder if you can get all you want if you talked to the right salesman from the dealer. my dream is the reg cab 4.0 with six speed manual, rear diff lock, vinyl floor upholstery, all the basics in the cab, but built mechanically built to kill. dont want any doodads.
GreenLion
Jun 7, 2021 10:49 AM
Niameyrider
Jun 25, 2015 05:50 AM
stanz
7
Jun 24, 2015 12:04 PM
