Pilot bearing removal the ez way!!
Old Jun 29, 2014 | 10:53 AM
sandman666's Avatar
I was installing new clutch, pressure plate, throw out bearing, and pilot shaft bearing this morning. I didn't have a puller so I drove to autozone to get a loaner one. They wanted a ridiculous $160 to rent an old used puller!!!! I didn't have that much cash on me so I headed back to the house pretty ticked off!! I hopped on YouTube and found this neat little trick. I really didn't believe it work but I figured what do I have to lose. I took a piece of bread and with an old bolt that just fit inside the bearing I kept smashing bread into the middle of the bearing until the cavity was completely full then drive the bolt in with a hammer. Smash more bread in and repeat a few times and wala bearing popped right out!!!! AMAZING!!!
Old Jun 29, 2014 | 11:00 AM
JasonYota's Avatar
First I've heard of using bread for this. You can also use grease or wet paper towels.
Old Jun 29, 2014 | 12:25 PM
wyoming9's Avatar
Red face
I spent the money to buy a puller works great and no mess .
I gotta ask does one kind of bread work better then another ???
Old Jun 29, 2014 | 12:54 PM
millball's Avatar
Any health- conscious twig eater will tell you that whole grain is better than white.
Old Jun 29, 2014 | 05:21 PM
donomite49's Avatar
they don't charge if you return the tool.
so you can save your bread...
Old Jun 29, 2014 | 05:30 PM
MudHippy's Avatar
I've used grease and candle wax. I prefer the candle wax method since it's slightly less messy, and less wasteful(clean grease has better/more important uses IMO).
But if there's nothing else, there's always bread too...I guess.
Old Jun 30, 2014 | 02:03 PM
CobraRed's Avatar
I've seen the wet paper method first hand. Although I dont think pullers are too costly in general IMO
Old Jun 30, 2014 | 04:09 PM
rattlewagon's Avatar
Weve always done it with grease. That how the haynes manual says to do it.
Old Sep 1, 2014 | 12:03 PM
tocarunner's Avatar
yeah I've heard of this also with wet paper. I had zero luck when i tried this.
he's gone
7
Dec 3, 2019 07:08 AM
akamon808
3.4 Swaps
Dec 16, 2015 08:45 PM
Sep 4, 2015 09:27 AM
JAmdor3
Aug 11, 2015 10:53 AM
norcal98
Aug 10, 2015 06:20 AM
