painting my stripes?
Old Dec 12, 2008 | 07:20 AM
99SR5's Avatar
so the stripes on my 1st gen are very faded and if i take them off the paint will probably look like crap so i want to paint them black. i was wondering what i can use to actually keep it from peeling and coming off when washing it and such.
Old Dec 13, 2008 | 03:04 PM
breknraj's Avatar
You could probably remove the factory stripe, and use the protected versus faded paint as your "template". Mask off, and paint away.
You could also check with James Dean Creations (he's a member, here), and see if he has the replacements for youe stripes.
Old Dec 14, 2008 | 01:27 PM
99SR5's Avatar
yeah i found a place that has the stripes but i dont feel like paying a few hundred bucks on stripes.
Old Dec 14, 2008 | 02:01 PM
JasonWin's Avatar
If you're gonna paint anyway why not just remove the stripes?
Old Dec 15, 2008 | 06:22 AM
99SR5's Avatar
how would i be able to remove them. i saw somewhere that you can buy like a big eraser for a drill and take it off that way but im not sure what my options are
Old Dec 15, 2008 | 07:34 AM
mt_goat's Avatar
I've taken stripes off before with a hairdrier and adhesive remover, but they weren't very old (couple years). I think it gets harder the older they get.
Old Dec 15, 2008 | 08:05 AM
dmorenoprieto's Avatar
Hey, I found a write up a while ago but I can't find it again. It is time consuming but pretty easy. I used a hair dryer but a heat gun will work as well. I heated the corner of the stripe and with a razor blade picked up the corner. As I heated the striped I pulled it slowly. For me this only removed the stripe, there was some adhesive left which I cleaned with acetone or adhesive remover. I don't care how it looks because I am bedcoating the whole exterior. Good luck!
Old Dec 15, 2008 | 08:12 AM
scuba's Avatar
I remember that as well, But i dont recall if it was for the adhesive after you got it off, or the whole stripe surface...
Old Dec 16, 2008 | 02:16 PM
maxpower_hd's Avatar
I used a heat gun and a razor blade. Then Acetone and elbow grease. I was repainting anyway so scratches were not a major concern. They also have plastic razor blades.
Old Dec 16, 2008 | 05:37 PM
99SR5's Avatar
ok well i guess ill be using a heat gun and razor blade lol.
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
1985 4Runner
Sep 30, 2015 10:17 AM
dbollier123
Sep 29, 2015 05:23 PM
