Old Toyota 3VZE Advertisement!
Old Aug 1, 2010 | 07:36 PM
az4x4runner's Avatar
Talking Old Toyota 3VZE Advertisement!
My wife was looking through some old magazines she has.. she found this in a 1988 Rolling Stone magazine. I thought it was pretty sweet and figured I'd share with y'all.
Sorry the pics aren't the best.. woulda scanned it but my scanner isn't hooked up at the moment.
Old Aug 1, 2010 | 08:01 PM
yotaman90's Avatar
That's pretty awesome!
Old Aug 1, 2010 | 08:02 PM
seanmearse's Avatar
Suprisingly the 3.0 in my runner is actually wery peppy still.
Old Aug 1, 2010 | 08:06 PM
yotaman90's Avatar
Just like any engine, it's all about maintenance
Old Aug 1, 2010 | 08:08 PM
Yep. I love my 3vze. 183k and running like the day I got it (or better).
Old Aug 1, 2010 | 08:11 PM
yotaman90's Avatar
Contrary to popular belief, I've had far more problems with my 22R than with my 3VZ-E
Old Aug 2, 2010 | 09:55 AM
b.miller123's Avatar
That's pretty sweet. Another 3vz owner here. No complaints so far. It has way more power and torque than my 22re did, and gets close to the same miles per gallon.
I'll most likely rebuild it when it blows, unless I can find a good deal on a lexus v8.
Old Aug 2, 2010 | 10:28 AM
Blue Steel's Avatar
210,000 yesterday. shes my baby, although im doing a 3.4 swap when this one kicks the bucket. maintainence, maintainence, maintainence.
Old Aug 2, 2010 | 11:44 AM
MudHippy's Avatar
Dude! Your wife kicks ass!!! I've been looking all over for that!!!
I've searched far and wide for anything that relates to the 88 3VZE specs. Many things changed with that engine after 88, and I'd like to know what all those things were. I already knew about the 145 hp thing. They later upped that number to 150 hp. How much later, how they did that and why, I can't say for sure. Though I believe, from what I've gathered, that sometime after 88(my guess is 89)they changed the valve clearance specs. Tightening them up by 3 thous. for the intake 2 thous. for the exhaust, thus giving that amount more valve lift for both(better for performance, esp. if you keep them at the tight end of those specs, see below). The ECU is also slightly different after 88, with a greater total pin count and different plugs, and it may have been updated software wise to get the 5 more hp AND, if my other evidence proves true, 9 more ft.lbs. of torque raising it to 189 ft.lbs. I also have some evidence that shows other clearance/tolerances were changed after 88 too. Namely piston ring clearance, connecting rod big end ID, and rod bearing min. thickness. Evidently the big end ID got bigger to fit thicker rod bearings.
My evidence for the valve clearance change after 88 is pretty solid. I have a pic of the sticker under the hood of mine showing it as being different from the current FSM specs.
Valve clearance (Cold):
Intake
0.18 – 0.28 mm (0.007 – 0.011 in.)
Exhaust
0.22 – 0.32 mm (0.009 – 0.013 in.)
http://personal.utulsa.edu/~nathan-b...68cylinder.pdf
I have the un-edited version of that pic somewhere, it just doesn't show the faded/painted over letters too good in some spots. So I filled them in for easier viewing.
Anybody got a sticker on their 88 that's still readable? I'd like a better pic.
BTW, I have my valves adjusted to current specs. For obvious reasons...
Here's the other piece showing the 88 3VZE specs being 150hp and 189ft.lbs. of torque. But I presume those numbers are the ones released sometime after 88 production had started. So at least late/MY 88 or 89. Who knows?
Edit: More current info, must be from a 95+ T-100 engine manual
Well...there it is in black & white. 9.0-1 Compression, 150 HP and 180 ft.lbs. of Torque.
Old Aug 2, 2010 | 12:05 PM
2+2=4Runner's Avatar
That is cool, my 3vze is running strong in the 88 4runner with 215,000 miles on it...unfortunately, i just noticed that I have a brake line leak!
Old Aug 2, 2010 | 04:24 PM
MudHippy, glad she could help you in your information gathering.
That's very interesting they decided to make some small changes after its initial release. I have always heard the torque is 180 ft.lbs. also, glad to have learned I got that extra 9.
Old Aug 2, 2010 | 04:59 PM
yotaman85's Avatar
I would kill to have that truck brand new..
Old Aug 2, 2010 | 07:57 PM
Yeah man... all the old Toyota ads up to 1995 make me feel that way, mostly the ones up to 1989 though since I already have a 2nd gen.
Old Aug 3, 2010 | 04:18 AM
BackGateYota92's Avatar
thats a cool advertisement,i love watching all the old commercials on youtube too. im also a proud 3.0 owner here. lol i wonder if the toyota v6 really outperformed other v6's of its day???
Old Aug 3, 2010 | 07:06 AM
nosfanatic2006's Avatar
My 3.0 WAS running good. Then a buddy and me were doing some work on it and I got sick, so he decided to finish it himself and screwed it up
Old Aug 3, 2010 | 03:52 PM
What did he do to it?
Old Aug 4, 2010 | 06:00 AM
I had a fuel leak. Got new injectors and o-rings. Got sick. He decided to fix it himself. Idle went insane. Towed it home to fix myself without him involved. Noticed a fuel smell coming from the engine the next day. Took it in to Toyota to figure out the idle problem and they informed me I had a couple leaky injectors, along with a list of other things.
My guess is he didn't lube the o-rings, and overtightened the fuel rails; just cause he's the type of guy "The tighter the better"
Old Aug 7, 2010 | 07:19 AM
tblake88runner's Avatar
My just blew up yesterday. I need a longblock. I have discount shipping if anyone knows where to get one for under $1600 please let me know.
Old Sep 18, 2011 | 05:01 PM
bbrideau's Avatar
my 3v is running strong at 372,000 km haha and it still has some get up and go. im gonna do a 5v supercharged swap in it tho
Old Sep 19, 2011 | 03:14 AM
nmtoy's Avatar
That is cool. I just bought a white version of that truck on Saturday. I flew to Phoenix and drove it back to Albuquerque.
People rip on the 3vze but I have had good luck with them.
I've had lots of 22re's and for about the same gas mileage the 3.0 drives so much better.
Mudhippy: I will see if I can get you a good pic of my underhood sticker.
My new baby:
Sep 4, 2015 09:27 AM
smiley52
Jul 11, 2015 05:16 AM
nick b
Jul 11, 2015 04:38 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
