new spark plugs= pinging?
Old Jan 17, 2008 | 09:14 AM
infiltrator's Avatar
hey yotatechers, i recently changed my girlfriends spark plugs on her honda. we went to two places, all they had was laser platinum spark plugs, irridium for the NGK and denso brands. then they had the crappy autolites. so i took the NGK irridiums. i put them in her car just like i did in my truck, i think i may have done something wrong because the car pings. im guessing its the spark plugs, maybe it could be something else.
i put the plugs on pretty tight, then a 1/4 turn (thought that was the standard)...
anyways, i thought i did a good job, how can i fix this. if its not, we have to try high octane gas...
we just bought the car too, so it might have those "undiscovered problems"...
Old Jan 17, 2008 | 09:23 AM
rdlsz24's Avatar
Maybe try getting oem replacement plugs? It seems imports are picky about their plugs.
Rob
Old Jan 17, 2008 | 09:49 AM
i would, but its like we just paid like 30 bucks for them. should have just gone to honda. do you think its because of the way i put them in? or the plugs themselves?
Old Jan 17, 2008 | 10:02 AM
rdlsz24's Avatar
Dang $30? So they were around $7 apiece? I'm not sure if over-tightening them would affect how the engine runs. I guess you could try loosening them up a bit.
Rob
Old Jan 17, 2008 | 10:35 AM
MSR's Avatar
MSR
can you give me the specifics on the car and part number plug you used
Old Jan 17, 2008 | 10:44 AM
89macrunner's Avatar
did you gap the plugs to spec?
Old Jan 17, 2008 | 01:43 PM
the plugs were pre-gapped. i put them in pretty tight. maybe i should loosen them up... ill try that. ill get part number soon.
Old Jan 18, 2008 | 11:43 AM
well, we tried high octane gas. still pings. guessing its my spark plugs. ****. ill just get the honda ones. please help me, how tight do i turn spark plugs.
Old Jan 18, 2008 | 03:10 PM
can anyone shed light on this problem. and help me on how tight to turn spark plugs?
Old Jan 18, 2008 | 05:17 PM
MudHippy's Avatar
I've come across many supposed "pre-gapped" plugs that were no where near the correct gap. A couple have been as much as .020" too much even, and they were platinum and the "non-adjustable" gap type like your iridiums. So, in my book there's no such thing as "pre-gapped" spark plugs, that's a myth. ALWAYS check the gap before installing.
I would check the spark plug wires too, make sure all connections are tight, ohms below 25k(or whatever Honda specifies).
1/4 turn past finger tight should be fine. That's if they have the gaskets, if they're the no gasket type more like 1/16 turn.
Old Jan 18, 2008 | 07:13 PM
okay i think i put them in wayy too hard then. ill loosen them up, if that does work, ill swap the irridium's to my other car, and then go get honda oem plugs.
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
raptor510
Aug 19, 2015 02:15 PM
accuracy
Aug 4, 2015 08:05 PM
defrag4
Jul 31, 2015 10:50 AM
