Misfire after engine cleaning
Old Jul 22, 2006 | 08:11 PM
bmwpower's Avatar
So I cleaned the engine today (simple green and water). After cleaning, I'm getting what sounds like a misfire.
I pulled off all of the plug ends to see if there was water down the holes. Nothing. I'm going to take a look at the MAF and give it a cleaning.
Anyone know what the problem might be?
Old Jul 22, 2006 | 08:25 PM
ebelen1's Avatar
I know you checked the plugs for water but that's what happened to me when I first got the truck. Decided to get a detail and they blasted the motor w/ water and it would idle funny. They tried blowing compressed air into the spark plug areas but to no avail and eventually a CEL (didn't look up the code). After we swapped in new plugs, no CEL and it ran great.
BTW, you didn't get water into the airbox, did you?
Old Jul 22, 2006 | 09:40 PM
bmwpower's Avatar
No water into the airbox. I just shot carb cleaner over all the hoses to see if there was a vacuum leak, but to no avail. Cleaned out the MAF with electrical spray - no luck.
I tried putting my code reader on the truck, but the darn thing isn't being detected!...figures. And I need the truck by tomorrow morning, 10:30. I think I may be screwed.
Old Jul 22, 2006 | 09:54 PM
msw0085's Avatar
i had the same problem with detailing my engine. I replaced the plugs and wires and solved the issue.
Old Jul 22, 2006 | 10:54 PM
bmwpower's Avatar
Looks like I'll try and replace both the wires and the plugs tomorrow morning. I'll let you know what happens.
Thanks!
Old Jul 23, 2006 | 09:35 AM
NC-B17A's Avatar
check your dist cap. The seal around mine was cracked & let water leak in the cap.
Mine would missfire when I washed the motor.
Old Jul 23, 2006 | 10:40 AM
L33T35T 4Runner's Avatar
if he has the 3.4, he doesnt have a distributor
Old Jul 23, 2006 | 12:04 PM
bmwpower's Avatar
New plugs and wires fixed it. 2 of the plugs had a little water in the holes, even though I blew the heck out of them with the air hose. Go figure. Thanks guys!
Old Jul 23, 2006 | 01:47 PM
Adam F's Avatar
This happens to me every once and a while. Just driving around for 15 minutes or so will dry things out and fix the problem.
Old Jul 23, 2006 | 02:44 PM
ebelen1's Avatar
You were lucky or you didn't have as much water in the holes. I drove the truck around two days sputtering after blowing compressed air in the spark plug holes to no avail. I guess it dried up after a few days but the plugs were all messed up and needed to be replaced...
Old Sep 16, 2008 | 06:58 PM
postalxj's Avatar
Iknow this old but this just happened to me on mt 01 SR5
I put a code reader on it and it showes a #6 cylinder miss fire a just checked all of the plugs and no water so i guess im going to get new wires and plugs and try that just hope on of the coils is not bad
Do any of you know what cly is #6
im still learing the Toyota
smthwsn357
May 1, 2024 07:28 AM
icentropy
Sep 16, 2020 02:47 PM
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
razorman8669
Jul 12, 2015 12:13 PM
