Mile marker hub install help
Old Apr 11, 2006 | 08:32 AM
tc's Avatar
tc
The splines on the hub need to engage the splines on the end of the CV.
Old Apr 11, 2006 | 05:36 PM
wailukutoy's Avatar
The hub body does engages to the cv, then the cover engages to the outside of the hub body gear when locked. But is the cv shaft supposed to be protruding out of the hub body or does it not have to? Sorry, don't know how else to explain my quest. Hopefully I can take a pic to show what I mean.
Old Apr 11, 2006 | 06:10 PM
tc's Avatar
tc
Yeah, pic would help
Old Apr 11, 2006 | 07:53 PM
wailukutoy's Avatar
pic post
you can see that the cv end is inside of the hub body. The end nut cannot be screwed all the way in because of this. Is it supposed to be like this. THe hub is on all the way.
Old Apr 12, 2006 | 04:48 PM
  #25
tc's Avatar
tc
You mean the screw that goes in the end of the CV axle with the big washer?
It looks OK, but you may need to push more of the axle through from the back side to get the screw started. Be careful not to tear the boot! Then as you tighten the screw, it should pull it to the right place.
Old Apr 12, 2006 | 06:06 PM
  #26
wailukutoy's Avatar
special bulletin
The nut not properly fitting, was actually the reason why my cvs would lock up at higher speeds. There is actually a special bulletin that superwinch had about this specific problem. No one seemed to know about it, until I made them dig several times to find a solution to my problem. Why it was not released to the public is a mystery. I had to call superwinch several times before I got a hold of this. Hopefully I can somehow get these parts I need. This is the bulletin and hopefully it may help someone later if they encounter the same problem. Thanks for all the help though, appreciate it.
Old Apr 12, 2006 | 06:08 PM
  #27
wailukutoy's Avatar
Sorry the pic is so big, forgot to resize it
Old Apr 12, 2006 | 06:16 PM
  #28
tc's Avatar
tc
I thought you said you had ADD hubs with the splined plate - not automatic.
I don't think that bulletin applies to you...
Old Apr 12, 2006 | 06:28 PM
  #29
wailukutoy's Avatar
It is an add, but the warning at the bottom about the inner spline not extending past the spline gear is the problem I'm having. It seems as though the "stop plug" and hex bolt" will fix this problem by putting a spacer between the cv end, and the hex bolt that screws into the end. The bottom warning seems to talk only about the hubs, regardless of whether or not its add or auto, which would be different behind the hub body. Is this not true?
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
razorman8669
Jul 12, 2015 12:13 PM
ItsJustD
Jul 7, 2015 07:49 AM
Vargntucson
Jul 4, 2015 12:15 PM
