LSPV which line is which?
Old Oct 11, 2009 | 04:23 PM
nikh713's Avatar
which is the pressure line and which is the return line? top or bottom?
Old Oct 11, 2009 | 05:27 PM
RobD's Avatar
There is no "pressure" or "return" line, per se.
http://www.autoshop101.com/forms/brake08.pdf
Make sure you read up on the difference between LSPV and LSPBV. There is a difference.
Old Oct 11, 2009 | 06:26 PM
nikh713's Avatar
i replaced both lines to the rear but affraid i mixed them up, with my abs (all wheel) it has a return line i guess from the rear that t's the pressure line to the front wheels under the master cylinder, the other "pressure" line i guess it would be comes strait out of the ABS to the rear. but i dont remember which line was which. and i'm having problems after fixing the broken line. i'm only getting brakes in the rear and i cant get the air out of the system ( mushy pedal)
Old Oct 11, 2009 | 11:03 PM
RobD's Avatar
Truth be told, I pulled the LSPBV out and ran one line off the front to the back and blocked the other from the front.
Upside, I have way better brakes than I did before.
Potential downside, the back end could try to outrun the front under heavy braking. I haven't had any problems yet, with the rear ABS keeping the back end in check.
Rickstwowheels
Sep 10, 2015 03:51 AM
87toy pickup
Sep 7, 2015 06:42 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
