Lowrider yota's
I have seen so many mintrucks mostly s-10's, sonoma's, nissian's and mazad's
I haven't seen that many toyota's.
It would be cool to see who all here has lowered yotas. static, hyd., and bagged.
Who knows if at all passable we could all get together cruz and lay some sparks.
You will have much better luck here: http://forums.minitruckinweb.com/index.html
99.9% of us go the opposite direction
Although, depending on how big the rocks are, we lay sparks too!
Thats stupid. Who cares what you drive. Wheel and have fun. (or in your case, "low ride" or whatever you call it)
I roll with mostly s-10 drivers, but it would be cool to get some ideas and see some tricks done on Toyota's. when i had a s-10 we all swapped parts and ideas and all that. Now that I'm getting into Toyota's it would be cool to link up with some Toyota drivers as well. duaaaaa
I'm going to try to get one as soon a possible. It's a 86 stock mustered yellow long bed. I'll be starting off with 3" drop block in rear and dropping the f. to match with the lowering of the t. bars. That's why i want to see some other dropped Toyota's to get some good ideas, tips and tricks.
From: Yotatech, because Pirate is too expensive. NorCal.
Heres my '82. I wanted to do the torsions and blocks but I noticed there is about 3 inches between the axle and frame and its my DD so I dont want it to ride like sh"t.
http://toyotaminis.com/forum/index.php also http://www.streetsource.com/Forum/default.aspx? . your not going to get much love on this forum.
www.tirefactory.com/virtualwheels.cfm
That is a fun tire simulator/time waster!
No old trucks though
LittleUgly
15
Jan 2, 2020 01:30 PM
primordialbeast117
Dec 19, 2015 12:23 PM
