Lower Ball Joint ???
Old Jun 8, 2006 | 08:05 PM
AKennedy87's Avatar
Question Lower Ball Joint ???
I am stuck and very frustrated! The lower ball joint on my 87 4Runner is stuck, not in the control arm but in the spindle. I got it loose from the control arm with the pickle fork and now it won't seperate from the spindle.
Any tips?
I have tried inserting the pickle fork in the little slot between em, using a bottle jack to seperate the a-arms, etc.
Has anyone else had this problem, can anyone give me advise?
thanks,
AK
Old Jun 8, 2006 | 08:10 PM
ChickenLover's Avatar
Did you try pounding it in the slot with a hammer? Pounding a wedge into that slot is really your only option.
Old Jun 8, 2006 | 08:15 PM
AKennedy87's Avatar
Yea i tried that, i am going to try it with the tire iron handle tomorrow, if not I'll have to pull the cv boot. Things suck man, i pulled them off of the spindles I got with this lift kit i got, took a good beating even then with nothing attached to em.
Old Jun 9, 2006 | 01:42 PM
AKennedy87's Avatar
So it took me and my dad a sledge hammer and the pickle fork just to seperate the lower from the spindle on one side.
Still another side to go.
Putting the lower on I broke one of the mounting bolts in the spindle, good thing I got an extra set for my lift kit thats going on in a few weeks.
Also before greasing these things I may have tightend one of grease points too tight, thus stripping the hole a lil bit.
How much grease should u have in these things, should the rubber be filled all the way up?
What a PITA, I hate IFS on Rustbucketsss....
aowRS
Sep 13, 2017 08:22 AM
Odin
Sep 24, 2015 04:38 AM
JRB4Runner2015
Sep 20, 2015 12:29 AM
Regency
Sep 6, 2015 05:47 PM
