Innovative?/header question
Old Dec 22, 2007 | 11:15 PM
87AzRunner's Avatar
so me and my brother were out romping around in the desert
and came across about 20 used fire extinguishers that somebody had
left behind. someone had dumped them (those ppl piss me off)
and there were a bunch of fire extinguisher mounts left so i decided to
be a little innovative, i thought id make a water mount of some sort out of it
so i could have water in my truck at all times.
i discovered a two liter works perfect so i peeled the label off cleaned it out
and filled it with water. now i wouldnt use the same bottle for more than a
year cause the plastic wears thin and you dont want water every wear so
just change it out every once in a while.
i decided to do two on the rear rollbar in the triangle since its outta the way
all you do is pic a spot and hose clamp or zip tie em down
now i always have at least 4 liters of water with me not to mention the gallon
of distilled in my cargo box. innovative? sure, and its cheap.
all you need is:
two hose clamps
old two liter
and a fire extinguisher mount.
it just reminded me of those "cheap tricks" articles outta some 4wheel mag,
i cant remember the name of it.
good idea? i thought it was a good one for being a an idiot highschooler.
question
Any idea what kind of header this is? i dont think its stock, correct me if im wrong.
Old Dec 22, 2007 | 11:22 PM
DeathCougar's Avatar
Definetly not a stock exhaust manifold.
Appears to be NW offroad, looks exactly like the NW offroad "Tri-Y" one I installed in my 87. LC engineering headers require relocation of the O2 sensor further down the pipe.
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
Steezy96yota
Jul 6, 2015 10:00 AM
