IFS hubs on Solid Axle
Old Aug 31, 2009 | 06:56 PM
Justinvd's Avatar
Just wondering if anyone has ever used this set up. Im missing a few peices from my sa hubs and figured i might try something else before hunting the peices down.
http://www.sky-manufacturing.com/new...uct.php?id=127
Old Aug 31, 2009 | 07:49 PM
nv4runner's Avatar
I read here that you can use IFS hubs on a solid axle, but not the other way around. 7th paragraph down says it. Good article too!
Old Aug 31, 2009 | 08:07 PM
mikepr55's Avatar
wow that ford 9 inch toyota hybrid is sick sure wish I could afford that. I would try the hub conversion if it was a upgrade Is it?
Old Aug 31, 2009 | 08:10 PM
tc's Avatar
tc
Do you mean the whole hub (brake rotor, etc) or just the manual hub?
The Pirate thread is the place for using IFS hubs/rotors instead of wheel spacers.
Longfield has manual hub gears to use IFS AISINs with SFA.
http://www.longfieldsuperaxles.com/
Old Sep 1, 2009 | 05:16 AM
Adam F's Avatar
Here's the deal guys.
First off, the LOCKING HUBS, which is the part with the dial, are NOT interchangeable from IFS to SA. SA has a 30 spline gear and the IFS is 26 spline. Some of the other internal parts are interchangeable though.
The HUB BODY, which is what the OP linked to, can be swapped if you use the right parts. Basically, you use IFS HUB BODYS, LC rotors, IFS calipers, SA LOCKING HUBS, and the special spacer. This gains 3" of width over the stock SA length.
I've never used it, but plenty of people on pirate use it with no problems that I know of.
Old Sep 1, 2009 | 05:23 AM
AxleIke's Avatar
The HUB BODY, which is what the OP linked to, can be swapped if you use the right parts. Basically, you use IFS HUB BODYS, IFS rotors, IFS calipers, SA LOCKING HUBS, and the special spacer. This gains 3" of width over the stock SA length.
Sort of. Stock you cannot convert them. With the longfield gear above, you absolutely can.
Guys on pirate are running IFS hubs with no spacers just fine.
Old Sep 1, 2009 | 05:35 AM
Adam F's Avatar
I've never seen these. Pretty cool. But at $65 a pop, you can find used SA hubs for a lot cheaper. Good for a strength upgrade, but not to simply use to convert IFS hubs to SA.
Old Sep 1, 2009 | 06:54 AM
AxleIke's Avatar
If you have IFS hubs though, its not bad. I plan on using those for a FF set up in the back.
Old Sep 1, 2009 | 10:25 AM
tc's Avatar
tc
Also, the hub gears are required for the lifetime warranty on the Longfields to be valid, so you're gonna pay it anyways - this just opens up your selection for hub bodies A LOT.
Old Sep 1, 2009 | 11:03 AM
algranger's Avatar
Plumbrbob runs those. Seems like a good setup
Flying91
45
Apr 11, 2024 04:39 PM
gieselman
Oct 12, 2015 01:34 PM
priest16
15
Aug 6, 2015 07:43 AM
deepmarsh
Aug 6, 2015 03:44 AM
scottyg486
Jul 19, 2015 05:34 PM
