How Well Do Tire Plugs Work?
Old Dec 20, 2006 | 04:17 PM
all_terrain17's Avatar
I've used a plugs a couple times on my tires with no problems, guess I consider it permanent since they still are not leaking. The cheapa$$ plastic puncture tool always seems to break on me though
Old Dec 20, 2006 | 05:24 PM
millertime_t1's Avatar
If using a good plug that is installed correctly -- I have found that they will easily last the life of the tire!
Old Dec 20, 2006 | 05:38 PM
waskillywabbit's Avatar
A good tire plug kit is essential if you wheel and I've had plugged tires hold air w/o leaking no problem.
I sell them on my website if you need a good one cheap.
Old Dec 20, 2006 | 05:45 PM
milowilli's Avatar
These plugs are a temp repair.You should get the tire Plugged with a round rubber plug and patched from inside.I have had steel belt failures because moisture eventually got into the steel belts and causes rust.The belt then weakens and the tire deformes or bulges.
Old Dec 20, 2006 | 06:01 PM
  #25
CJM's Avatar
CJM
My brothers bucik I plugged 6 months ago and is holding just fine. He is a 17 year old kid and drives like a maniac, if its held up its fine in my book. It really depends on what made the hole and where it is. If its in the sidewall dont ever plug it, that could lead to a weak spot and a blowout. In the tread and its a nail and not a large cut or something then your fine.
I have always used those kinds of rubebr, sticky plugs they sell at wallyworld and they always have worked just fine too.
Old Dec 20, 2006 | 06:46 PM
  #26
SwampThing's Avatar
Yeah, all of mine are on the tread and not sidewall. Actually I found a picture of one nail in my back left coincidentally enough.
Old Dec 20, 2006 | 06:55 PM
  #27
SwampThing's Avatar
Oh, and thanks wab, your right, that same kit (cept came in a blue case) was around $30 at autozone! Will definitely be orderin through ya whenever I work myself out of my christmas debt lol...
voiddweller
19
May 2, 2016 09:10 PM
serenity03k64
Jun 27, 2015 07:59 AM
marcusSRG
Jun 27, 2015 07:13 AM
saphirekosmos
Jun 22, 2015 10:26 AM
gog1968
Jun 22, 2015 05:55 AM
