How many miles does everyone have?
Old Dec 27, 2012 | 09:56 PM
  #1061
cwjj9992's Avatar
206,700 on my 92 pickup
Old Dec 27, 2012 | 10:49 PM
  #1062
Donster's Avatar
From: East Mountain area of Albuquerque, New Mexico
To remove pilot bearing: I got a 1/2" wooden dowel (if you put calipers to the dowel, you'll find that it is a little less than .500), and one of my wife's home made flour tortillas. I got the tortilla and started cramming pieces of tortilla into the bore of the pilot bearing. Then I got the dowel and a hammer and tapped the tortilla pieces into the bore, added some tortilla, tapped it in with dowel, repeat process until bearing comes out. It truly is amazing how easy it was. Once the bearing is out, all you have to do is dig the compressed tortilla wad out of the cavity and you're done! I got the idea off of UTube except these guys used sandwich bread. It's the same idea as the grease trick but it's alot cleaner. Also, be careful not to hit the dowel too hard when it bottoms out, so that you don't do any damage to stuff on the crank shaft.
Old Dec 28, 2012 | 05:44 AM
  #1063
poleclimber63's Avatar
1998 4Runner SR5 3.4L Auto, 208K when purchased this Spring, in Canada! That's 208000 Kilometres= 130K miles! I lucked out!
Old Dec 28, 2012 | 04:44 PM
  #1064
idanity's Avatar
odometer stopped at 348,000 k miles
Old Dec 28, 2012 | 07:00 PM
  #1065
'884Runner's Avatar
277,500 on the '88 4runner and around 279,000 on my 1993 camry dd. 125 mile round trip commute. both still run like champs on the original engines and transmissions.
Old Dec 28, 2012 | 09:37 PM
  #1066
the_supernerd's Avatar
That sounds like a cool trick. It makes sense, but it is something I would have never thought of trying!
Old Dec 28, 2012 | 11:04 PM
  #1067
combatcarl's Avatar
Wet paper towels. The blue shop kind are best. Then pop bearing in freezer for a while, open fridge, grab a frosty brew, enjoy, remove bearing from freezer, pop 'er in, and go!!
Old Dec 29, 2012 | 03:44 PM
  #1068
boggsu2's Avatar
147k on a 88 pickup.
Old Jan 27, 2013 | 09:39 PM
  #1069
Fishyer777's Avatar
1987 2wd 22r pickup
202k
Only things replaced were the master cylinder, and steering rack. Not one problem since
Old Jan 29, 2013 | 08:49 AM
  #1070
mlitz69's Avatar
189,xxx in recently purchased 94 yota 4x4
Old Jan 29, 2013 | 05:43 PM
  #1071
Frankbirt's Avatar
1988 4runner has 103,000
Old Jan 30, 2013 | 02:56 PM
  #1072
Geeves's Avatar
192k on my '93 pickup only problem was the head gasket.
Old Feb 3, 2013 | 08:19 PM
  #1073
bentley3006's Avatar
329,000 on 94 ex cab 3.0 4x4
Old Feb 4, 2013 | 07:04 AM
  #1074
Bubba0's Avatar
345,245 miles on my 1989 pickup 4x4 and still truck'en
Old Feb 4, 2013 | 10:42 AM
  #1075
Aido's Avatar
Aido's Milage
That's in kms so for miles about 313,250 and 208,104.....and still going strong!
Attached Thumbnails How many miles does everyone have?-2013-02-04-14.27.41.jpg   How many miles does everyone have?-2013-02-04-14.27.14.jpg
Old Feb 4, 2013 | 12:48 PM
  #1076
MPC34668's Avatar
227000 on 1987 pickup. Numbers are sagged on dash and title says 270000. I'm thinking they rolled It back to 200k when it hit 300k. Oh well. No major problems yet. (Besides head gasket and other bs) knock on wood!
Old Feb 4, 2013 | 12:52 PM
  #1077
Austin Marr's Avatar
249,000 on my 3.0. Did the 3.4 swap, no idea how many miles it has. the old cluster said like 179k
Old Feb 4, 2013 | 02:26 PM
  #1078
Ugly4Runner's Avatar
232k on 1990 4Runner
53k on 1969 Dodge W300 4x4
Old Feb 4, 2013 | 03:06 PM
  #1079
Dave the welder's Avatar
235,000 on the truck and tranny everything else has been replaced. Shes had a hard life.
Old Feb 4, 2013 | 03:08 PM
  #1080
ROCKLAND TOYOTA's Avatar
185K on truck and trans with 0 miles on New motor.....
