How many miles does everyone have?
Old Sep 20, 2012 | 01:23 AM
  #981
ChefYota4x4's Avatar
Originally Posted by combatcarl
347,659 mi, as of last night. Just 20k on this engine. Back story...
Bought in 97 at Dirkes used dealership in Choteau, MT. One owner truck. In about late 99, timing cover had enough, made a milkshake. Rather than replace timing set and cover, dad decided an unknown condition junkyard motor was better...in 2000, tranny developed issues, probably related to JY motor, according to my uncle, a Toy and import tech. Rebuilt tranny. In 2002, rear 3rd member went, as a result of bad tranny rebuild. Replaced tranny and rear 3rd. In about mid 04, JY engine timing cover had enough, made a good bye milkshake. I split the cost of a "low mile imported " engine with my dad, and it lasted until...
March 08, when, on my mid tour leave, I learned I would be car-less for the duration of my stay. Kid sister nuked that motor, out "mudding". So in early 09, I located a rebuilder here local, and popped $1100 for a reman longblock, with a THREE YEAR warranty. Its been a great 3 years plus, and never misses a beat. Gets babied, flogged on occasion, runs 5w40 rotella, and is about to get a fill of redline lubes, duff's, trans and t-case. Mismatched bed is due to Portland's tri-met bus backing into it about the time the original motor croaked.
HOLY SISTER-DESTRUCTO! hehehe... I really enjoyed reading that, man... thanks for sharing.(Not the sister nuked it or the rest of the troubles.. I wouldn't wish that on.... Well, yes I would, but that's besides the point, You KWIMean! HAHA....).... CRAZY some of the stories these have. Imagine if that one on Top Gear could speak, right? haha... "Oh man, I was put in the ocean, demo'd on a building.... What about you, CombatCarlYota?" lol....
I had a question.... maybe someone can tell me, but I PROMISE I'll look it up...
I've had 31's on here since 100K miles.... My ODOMETER now reads 268,000, roughly... What are my ACTUAL miles with 168K of it being on 31's and 410's? (It's only been on 4.30's for a few thousand).... Around another 10-11K? (Thought it was 7.?% added for 31's and 4.10's)....
Anyway, it's great to see all this MILEAGE....and STILL ROLLIN!
Old Sep 21, 2012 | 07:05 AM
  #982
IITheKidII's Avatar
1989 Pickup 4wd 160,000
1994 Pickup 4wd 209,000 (still going strong)
Old Sep 21, 2012 | 11:25 AM
  #983
SPARKS89's Avatar
More done in the last 15,000 than in the first 190,000
89 Pickup 22RE 5 Speed (with about 2500 mi. on it) 4x4 with 204,000+ miles. Had it almost a year. Replaced transmission, clutch, flywheel, rear shaft u-joints, rear brakes, rear axle bearings and seals (and new rear brakes AGAIN thanks to all the gear oil), new TPS, replaced all vacuum lines with silicone, LED dash lights upgrade, replaced broken exhaust downpipe, battery/airbox swap, and sway bar removed. I've pulled the steering wheel to clean the connections so my stock horn works again (I HATED it when someone suggested adding a button somewhere on the dash for the horn). I also had to weave rope under the seats to give it suspension again because the tiny little wires that hold your butt up were destroyed by the ENORMOUS previous owner. Currently still searching for issues with the ECU. I have plans for new exhaust, EGR deletion, new suspension and body bushing, upgrade steering gear box, upgrade to the V6 front brakes, and maybe a lift, bigger tires, new gears and lockers (which will also include a V6 3rd member too) eventually.
Whew! It's a good thing I don't have a payment to make on this ol truck. It's 23 years old now and at this rate by the time it's 25 it'll be brand new again!
Old Sep 21, 2012 | 11:58 AM
  #984
GTB129YOTA's Avatar
From: Bay Minette AL., (Lower right limb of Alabama)
330,xxx on my 94 pickup 4x4
And climbing daily
Old Sep 22, 2012 | 09:20 AM
  #985
mickyd9990's Avatar
Only 112,900 on my 89 v6 auto pickup.. guy said the timing chain and waterpump and head gasket was done around 105,000 so hopefully I will be problem free. Knock on some wood
Old Sep 22, 2012 | 06:30 PM
  #986
BMcEL's Avatar
If he said he replaced the timing chain on a 3.0, he was lying.
Old Sep 22, 2012 | 07:16 PM
  #987
old fart's Avatar
90 4 runner, 214,000 miles as of today, blew the headgasket at 200,000, everything repaired, bronze shimmed etc. Now the clutch is starting to go.
And btw, i run 32x11.50x15, i'll let chef do the math, lol.
Old Sep 23, 2012 | 03:56 PM
  #988
mickyd9990's Avatar
haha oops thats my mistake there
Old Sep 24, 2012 | 03:58 AM
  #989
Renegade4x4's Avatar
1995 pickup 4cyl 22RE 156000
Old Oct 1, 2012 | 07:54 AM
  #990
jonnysrt2004's Avatar
90 4runner 3vze
264XXX still ticking. Leaks a little oil...
Old Oct 2, 2012 | 08:38 AM
  #991
YotaDakota's Avatar
I've got 274,884 on my '92 single cab 5spd 4x4 (not sure what exact model) as of right now. According to the receipts from previous owner (he was the 2nd owner) he had it rebuilt around 250k and new valve cover and head bolts. Has a timing issue due to old and worn coil and distributor cap, which are original along with the tranny.
Old Oct 8, 2012 | 06:19 PM
  #992
Usfbeta's Avatar
Miles on the Yota and questions
99 4 runner SR5 has 197,650!!!! It is beginning to idle rough when stopped and Its starting to bog down if I need to get on it. I step on the gas and it feels like it chugs three or our times and then will kick in and move. Any suggestions or thoughts on a possible problem? Thanks everyone.
Nick
FF/PM Pasco County Fire Rescue
Old Oct 8, 2012 | 06:44 PM
  #993
dazbert's Avatar
Nick
IIRC, Mass Airflow Sensor is likely needing cleaned. I would have thought you'd see a CEL but in any case I'd clean the MAF.
My 99 4Runner Ltd is at 268k and counting
Old Oct 9, 2012 | 03:59 AM
  #994
ZachMcDaniels2's Avatar
Nick
yeah i agree mass air flow sensor because my truck did the same thing happened to my truck.. but clean it VERY VERY carful because it was $265 for that lil joker.
Old Oct 9, 2012 | 06:22 AM
  #995
88Toy's Avatar
Nick
Mass air flow sensor, my buddy has a 99 Sr5 tacoma, it was doin yhe exact same thing, replaced the maf and boom runs great....212,200 on my 83 camry, and 182,000 on the 86 crawler!
Old Oct 9, 2012 | 07:12 AM
  #996
rognyt23's Avatar
187,599 on my 95 4runner (less than 100 since complete engine rebuild)
229,376 on my 96 4runner (is my rockcrawler and is in progress)
Old Oct 9, 2012 | 08:22 AM
  #997
midtnyota's Avatar
208k on my 1991 extended cab 4x4 22re.
287k on my wifes 1993 4x4 single cab 22re.
both driven daily and still going strong.
Old Oct 9, 2012 | 08:39 AM
  #998
azkingm's Avatar
230K on 95 4 cyl ext cab 4x4. Day driver, mountains, desert, and beach 4 wheeling and work truck. Routine maintenance and minor repairs. Just added 3" lift coilover shocks to front (sway-a-way / racerunners).
Old Oct 10, 2012 | 02:52 PM
  #999
Usfbeta's Avatar
thanks!
To all of you who responded, thank you very much! I am going to fix it on Sunday when I am not at work and I keep you posted.
Nick
Old Nov 3, 2012 | 04:08 PM
  #1000
WORMS's Avatar
