horn will not work
Old Dec 9, 2008 | 12:12 PM
yotaroad's Avatar
Angry horn will not work
hey there you all seem pretty knowledgeable so................
i have a 1990 toyota 4runner
the horn doesnt work
have power to the horn
if i disconect one side i lose power to both sides,,,,,so im figuring this is poer comming in.
if i ground the horn out at the horn it blows.https://www.yotatech.com/forums/imag...s/headbang.gif
if i ground it out at the wire that connects to the underside of the steering wheel i get nothing.
thought it was maybe a horn relay
looked in all the books i could get my hands on and nothing at all about the horn or wiring for the horn......no wiring diagrams anywhere.........
so i call the dealer........haha........they say the horn relay is down by driver side kickpanel above the taillight relay........well i had already tore into that and there is nothing above the taillight relay...................
AAAAAAAAAAAAAAAAAAAHHHHHHHHHHHHHHHH.....Help!https://www.yotatech.com/forums/imag...s/banghead.gif
Thanks for any comments
NEW
Old Dec 9, 2008 | 12:20 PM
yotaroad's Avatar
Also have checked the fuse,,,its good
i have no power up at the wire connecting to the sterring wheel,,,dont know if im suppossed to.
Old Dec 24, 2008 | 04:09 PM
Ron Helmuth's Avatar
umm yes the steering wheel "press" is the switch-so the power has to come in and then leave that "switch" to send the power to the horn(s)
hope that makes sense....
Old Dec 24, 2008 | 05:11 PM
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
I'd say its your crankshaft...
But on my truck the horn only blows when the steering wheel is turned to the left. I don't know what year your truck is but try turning your wheel to see if it makes contact anywhere.
Old Mar 12, 2022 | 08:30 AM
barleyw's Avatar
Did you resolve this?
Did you fix your horn issue? What was the problem?
ashersullivan88yota
Jan 18, 2022 05:37 PM
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
madxman21
Jul 9, 2015 10:26 AM
