Help! Lift and tire question???
Old Jun 7, 2006 | 10:06 AM
89red4x4yota's Avatar
ok i currently have a stock suspension and am running 31x10.5 on 15x8 mickey thompson rims they stick out a bit and im running them without any rubbing, if i go with 33x10.5 tires and i lift it one inch with a one inch body lift i should be able to clear the 33's because they are the same width just taller therefore the one inch should clear them without any problems??? im thinking go up 2 inches so 1 inch all the way around the tire so 1 inch body lift??? am i right or wrong???
Old Jun 7, 2006 | 11:05 AM
celica's Avatar
an inch plus an inch pluss 33 from 31 plus body lift plus rubbing plus amount of lift plus ??? marks = SEARCH AND YE SHALL FIND
Old Jun 7, 2006 | 12:38 PM
i did search however it says i can fit 33x10.5 with no lift on stock rims, i was wondering what i would need for the rims i have now they have a 3.75" backspacing and just about miss the front valance when i turn.
Old Jun 8, 2006 | 05:36 AM
celica's Avatar
the thing that you will want to measure is clearance under compression & turned. If you have your rims sticking out then that wil change the whole equation. I would probably start a new thread about the backspacing. When you start one about lift & not give all the details people will tend to ignore it. What is your measurements between the tire & any fender valence etc. now?
Old Jun 8, 2006 | 06:01 AM
4Runner92sr5's Avatar
Well your getting 33x10.5's soo even with 3.75 backspacing you should in theory be fine. I have 32x11.5 and i clear my valance by a half an inch. I trimed mine for better approach angle though and cuz of later 33x12.5's . But if they do rub with 33x10.5 then you can just slightly trim your valence where it rubs. Simple as that.
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
Yotoder865
Jul 9, 2015 07:51 PM
