Grinding in front HELP!!
Old Oct 14, 2007 | 02:17 PM
blueyoda's Avatar
While 4wheelin this weekend a grinding noise began in the front end. It happens when you let of the gas and coast. The closest I can compare it too is when the abs engages, the same high vibration. There is also infrequent vibration at speed when the hubs are locked, goes away when unlocked. Any ideas would be apreciated.
Thanks
Old Oct 15, 2007 | 02:16 PM
4Crawler's Avatar
Spindle bushings are a likely culprit, I think there is a needle bearing replacement for them:
http://www.4x4wire.com/toyota/maintenance/front_end/
Old Oct 15, 2007 | 05:14 PM
tc's Avatar
tc
x2 for spindle bushings.
There's a writeup in the tech section about how to make a device to make it easier to lube them.
Old Oct 24, 2007 | 06:34 AM
blueyoda's Avatar
Thanks,
I bought the nut from yota and I am welding up the tool tonight
jashoeuh
Nov 18, 2024 08:08 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
PlayAwhile
Jul 20, 2015 11:36 AM
kvanzandt1
Jul 18, 2015 10:15 AM
mengquis
Jul 13, 2015 10:39 AM
