Friend's oil drain plug stripped
Old Jul 24, 2006 | 11:30 AM
joshik's Avatar
hi yall im posting for my friend
he has a 1986 Corolla GTS (AE86).
he was trying to pull his drain plug from his oil pan to do an oil change. he stripped the heck out of it and pretty much the plug is round now. what can he do to get it out?
any suggestions?
thanks!
Old Jul 24, 2006 | 11:35 AM
Tacoma Dude's Avatar
Just about the same thing that you'd do for any rounded bolt. The first thing that comes to mind, of course, is some good vice grips. Might help to spray it down with PB Blaster if possible - sounds like it's on there pretty good.
Search rounded bolt and I'm sure you'll find a whole long list of other ideas as well.
Old Jul 24, 2006 | 11:45 AM
Intrepid's Avatar
Grab a set of Bolt Out's. They work AMAZINGLY well! I Was hesitant at first, figuring they would probably just mangle the bolt, but I had a gift certificate so I got them. I have used them 8-9 times now on multiple different vehicles and I am in love. They are my new favorite tool!
Old Jul 24, 2006 | 11:48 AM
joshik's Avatar
where would u get a set of these? i did a search on YT and dogpile. couldnt find much info on them.
Old Jul 24, 2006 | 11:51 AM
Adam F's Avatar
First I would go to the store and get one of those universal drain plugs that look like drywall anchors with the wing on them. Like this....
http://cgi.ebay.com/ebaymotors/UNIVE...QQcmdZViewItem
Then try a vice grip to get it off.
Last ditch effort would be to take a cut off wheel and slot it, then use a large pry bar like a screw driver to get it off.
Old Jul 24, 2006 | 12:59 PM
Bennito's Avatar
Or....abandon all hope of ever getting that plug removed. Several oil service companies (oil butler, here in town) will suck the oil out via your dip stick tube.
That wouldn't be my solution - but if you take your car to jiffy lube its really no big price difference.
Old Jul 24, 2006 | 01:52 PM
joshik's Avatar
what if, instead of slotting it with a cutting wheel, grind the sides to make it a smaller plug, like 13mm or 12mm.
Old Jul 24, 2006 | 02:00 PM
Churnd's Avatar
That's a worthy idea, but would take a LOT of precision. You're better off getting vice grips. Any hardware store will have 'em. Heck, I think WalMart would have 'em. Then get another new plug from somewhere. PM strap22 and see if he can get you one.
Old Jul 24, 2006 | 02:02 PM
joshik's Avatar
just a though. yeh, i told my friend to go to harbor freight and just pick up a pair of visegrips
thanks!
Old Jul 24, 2006 | 05:23 PM
Ringmaster's Avatar
Small pipe wrench.
Old Jul 24, 2006 | 05:28 PM
Intrepid's Avatar
Sears, they have some larger sets and some smaller. It is my favorite tool ever.
http://www.sears.com/sr/javasr/produ...TOOL&ihtoken=1
Old Jul 24, 2006 | 07:16 PM
kyle_22r's Avatar
i can vouch for the bolt-outs, they've even extracted siezed and broken head bolts for me!
Old Jul 24, 2006 | 07:20 PM
waskillywabbit's Avatar
I beat on a size smaller socket and mine came right off...then I swapped to a socket head drain plug to prevent that from happening again.
Old Jul 24, 2006 | 08:13 PM
boogyman's Avatar
instead of trying to make it fit a smaller socket, just file down 2 sides of it so you can grab it with a pair of pliers and loosen it.
Old Jul 25, 2006 | 08:08 AM
Marc's Avatar
Originally Posted by Ringmaster
Small pipe wrench.
I agree, small pipe wrench and cheater bar.
The harder you pull the tighter the wrench gets, until it breaks of course.
Jun 1, 2021 01:51 PM
Eggslinger
Jun 8, 2019 03:32 PM
Doug4320
Mar 24, 2018 10:11 PM
thefishguy77
Jul 30, 2015 10:59 AM
Gamble_STi
Jul 7, 2015 07:54 PM
