Found the squeak... What is this?
Old Jun 1, 2006 | 10:19 AM
Buck01's Avatar
Is it the rubber part that is keeping it held together? or the metal sleve?
Old Jun 1, 2006 | 10:27 AM
snap-on's Avatar
Originally Posted by JML
Would if I could Gerdo.... The problem is I can't seem to get the broken endlinks off. I purchased replacements, but the metal has fused together.
mmmmmm im always looking for excuses to fire up the gass axe!
Old Jun 1, 2006 | 11:27 AM
JML's Avatar
JML
The metal sleeve. It has fused together with the bolt. The bushings wore away and the metal was rubbing against the plate it screws into and the sleeve and bolt are one.
So now that i have the whole sway bar off, the endlink is still connected to the end of the swaybar.
Old Jun 1, 2006 | 11:29 AM
Buck01's Avatar
I assume you have soaked it in oil or penetrationg oil or such?
you could also try an air chisel...
Old Jun 1, 2006 | 11:38 AM
  #25
JML's Avatar
JML
Don't have many tools. But what type of oil would you recommend? That would also make it harder to grip the sleeve after the soak
Old Jun 1, 2006 | 11:40 AM
  #26
Buck01's Avatar
I use PB Blaster penetrating oil....just soak it every evening for a few days then try to remove it wiht a vice or channel locks or vice grips something like that.
shisha1999
Aug 14, 2015 01:33 AM
bighaydn
Aug 4, 2015 07:17 PM
irritech
Jul 27, 2015 05:15 PM
yourrealdad
Jul 21, 2015 11:13 AM
msane99
Jul 17, 2015 10:13 AM
