Found the squeak... What is this?
Old Apr 2, 2006 | 11:00 AM
JML's Avatar
JML
Had this truck for about a week. Trying to figure out how it works. I noticed a little squeek when going over bumps. Figured I should lube the suspension.
I was under it today looking around and found a bar that moves, creating the squeak. It also looks like there should be some bushings here.
Can someone tell me exactly what this is and that it's not exactly normal.
The first pic is looking from behind FL tire looking toward inside of FR tire. The bolt that goes through the plate has 3 bad looking bushings and then nothing below those.
The second pic is a bar that connects those 2 bolt/bushings and it moves, pushing the bolts farther through the plate creating the squeak.
Attached Thumbnails Found the squeak... What is this?-1.jpg   Found the squeak... What is this?-2.jpg
Old Apr 2, 2006 | 11:15 AM
Tofer's Avatar
Sponsor
thats your swaybar. you have a couple options. either replace teh bushings, get quick disconnects, or just take it off. with out a swaybar you will flex out alot better. i've had both my swaybars off for over an year and have had no problems.
Old Apr 2, 2006 | 12:01 PM
JML's Avatar
JML
Thanks!
So it looks like the sway bar bushings are in good shape. They are the things that hold the bar from 2 u shaped clamps.
I guess maybe these are the endcaps? (See pic)
If you follow the sway bar around to where the bolt connects on the end, there is a 5 inch long screw with 2 pathetic little bushings that only take up about 1 inch total.
Old Apr 2, 2006 | 12:06 PM
marko3xl3's Avatar
Are you sure those bushings look like they are in good shape? They look pretty beat up to me and I'd be willing to get that's where you are getting your squeak from.
Old Apr 2, 2006 | 01:10 PM
wrenchmonster's Avatar
That's the sway bar link. Those bushings are toast. Replace ALL the bushings with the sway bar, or remove the bar altogether. Alternatively, shorten the length of the links so there is not as great a pressure through the sway bar, thus increasing flexibility and at the same time still adding some road handling ability. The purpose of the sway bar is to dampen body roll.
You may have cut your own metal if you decide on the alternative as the bushings will probably come in a kit along with new links. Good luck.
Old Apr 2, 2006 | 01:28 PM
PirateFins's Avatar
If you don't offroad that much and don't need the flex, then just get poly bushing sway bar kit from energy suspension or daystar. It comes with all the parts you need to replace the old bushings and endlinks.
Old Apr 2, 2006 | 06:31 PM
JML's Avatar
JML
Can someone recommend a place to get these endlink bushings?
I'm having a hard time finding them, as the pics don't really look like what I need.
Thanks
Old Apr 3, 2006 | 07:53 AM
JML's Avatar
JML
Been thinking about removing the sway bar as that's cheapest fix... However, wouldn't I greatly increase the chances of going belly up? I would sure rather spend $40 than total my toy.
Also for the condition that the endlinks are in now... is it actually doing ANYTHING?
Who would you recommend buying the endlinks from, if I go that route?
Thanks
Old Apr 3, 2006 | 08:04 AM
cootees's Avatar
Everything you need right here in this link
Old Apr 3, 2006 | 08:11 AM
EWAYota's Avatar
I haven't had my sway bar attatched on my truck for almost 3 years now. Its not that big of a deal to drive without it as long as you realize its a truck and not a 'vette going thru "s" curves
Old Apr 3, 2006 | 05:56 PM
Swissdrums's Avatar
I pulled mine off today...it seems to ride fine, i just noticed when doing u-turns that the front of the car would tilt a lot more...looks like i will be saving some gas since i will drive slower now...woot woot
Old Apr 3, 2006 | 07:17 PM
Snorkeldepth's Avatar
Suffering from "squeak . . . . . squeak . . . . . . . squeakity-squeak . . . . squeak" . . . . I've been trying to figure out the source. Be thankful that you've identified the source of yours! Hope springs eternal, so I removed my swaybar after work this evening. I took it around the block and sure enough, "squeak . . . squeakity-squeak" while rolling along at about 30 mph on a mildly bumpy road.
Don't forget about the very cool and fabulously attractive WabFab Quick Disconnects!
Old Apr 3, 2006 | 08:21 PM
JML's Avatar
JML
I am not totally sure that's what causes the squeak I hear. I can wiggle the sway bar and hear a squeak. But there could easily be others!
Keep looking and let me know when you find yours what it was...
Old Apr 4, 2006 | 02:25 PM
My squeak goes away when it rains.
Old Apr 28, 2006 | 07:31 AM
JML's Avatar
JML
Anyone know where I can get a tube of "elbow grease"?
For the life of me, I can't get the endlinks off. I have tried squirting some silicone spray up there and bike chain lube. The bolts are fairly rusty and I'm holding the bolt with a wrench and using a socket wrench on the nut.
Contemplating getting a hacksaw to cut thru the endlink.
Any tricks for stubborn bolts would be greatly appreciated. I can easily get the bolts holding the Sway bar bushings, just can't get the endlinks off. Maybe cutting out the bushings with a razor blade will make it easier.
Old Apr 28, 2006 | 07:45 PM
^VooDoo^'s Avatar
Some of the AutoZone's have swaybar endlinks in there performance/bling section, $12
Old Apr 29, 2006 | 01:27 PM
JML's Avatar
JML
I have the parts... having trouble trying to get the end links off of the sway bar. Good news is that with sway bar off and skid plate tightened, no squeaks! Sounds great to drive around the block. Don't notice any body roll granted I'm only taking the turns at 25 mph at most.
Old Jun 1, 2006 | 07:14 AM
JML's Avatar
JML
I finally took the sway bar off after wrenching for about 2 hours and constantly slipping off the bolt, smashing my hand into the wheel. It wasn't pretty but I got the bolt loose and finally got it off.
But for the life of me, I can't get the end links off of the sway bar. There is a long bolt with a metal sleeve on it (kinda like a 3 inch long washer of diameter .5 inch, maybe called a metal spacer). After 200K miles, this thing is welded to the bolt. I broke my hacksaw trying to get one of these off, the other is no use either. I have spent about 3-4 hours sawing it (over the course of several days).
With my swaybar off, cross winds kill me. I feel so unstable, although I don't know how this truck will feel in a crosswind with a solid sway bar on.
How the hell do I get the end links off???
Old Jun 1, 2006 | 09:48 AM
Gerdo's Avatar
Keep the swaybar on. It reduces bodyroll. Replace the mount and endlink bushings with either poly or stock rubber.
Old Jun 1, 2006 | 10:00 AM
JML's Avatar
JML
Would if I could Gerdo.... The problem is I can't seem to get the broken endlinks off. I purchased replacements, but the metal has fused together.
