fan
Old Oct 28, 2008 | 04:28 PM
jason191918's Avatar
fan
Is a fan better off pulling or pushing air through a heat exchanger?
Thanks.
Old Oct 28, 2008 | 05:42 PM
4Crawler's Avatar
Probably depends on the fan design itself, some fans are made to pull air through and some to push air.
Old Oct 29, 2008 | 12:39 AM
Adam F's Avatar
From the research I've done, A pusher fan is only 80% as efficient as a puller fan.
Old Oct 29, 2008 | 02:13 AM
sixt5's Avatar
puller is better
Old Oct 29, 2008 | 06:48 PM
Thanks for the replies. How do I go about identifying what type of fan I have, or is it just about the direction (I assume all fans are reversible direction-wise though)?
Old Oct 29, 2008 | 07:03 PM
4Crawler's Avatar
Usually they will have a direction of flow or rotation arrow on the fan or shroud some place. Then will also have some sort of mounting flange/tabs on one side. Those two things will pretty much tell you how it is set up. If it is pulling air in from the side with the mounting tabs, then it is a puller.
Old Oct 29, 2008 | 07:31 PM
Thanks!
kawazx636
Oct 6, 2021 03:03 PM
voiddweller
Sep 28, 2015 11:21 PM
Matthew Perez
Sep 28, 2015 05:43 PM
runnermedic
13
Sep 21, 2015 05:20 PM
Aaron Logan
Sep 3, 2015 08:08 AM
