E-Locker test
Old Mar 24, 2008 | 11:22 PM
Five1Nine8Eight's Avatar
E-Locker test
Is there a way I can test my e-locker rear end to see if works? I bought it used and just bought an ORS e-locker harness and hooked it up and nada.
Can I hardwire something just to test the e-locker?
Old Mar 25, 2008 | 12:28 AM
89macrunner's Avatar
listen for the elocker to turn on. when you hit the switch you should hear it. Also. try engaging the locker and going around a turn. You will know if its on or not. sometimes mine doesnt engage untill i pull forward a little bit.
Old Mar 25, 2008 | 12:33 AM
Elton's Avatar
i think he means how to test it on the work bench
Old Mar 25, 2008 | 12:54 AM
I'll try to roll it around and see it it engages but I can't hear it switch at all. Shouldn't the relays click also? My AUX light relay clicks.
I'd like to do a work bench test to confirm if its the locker or harness that aren't working properly.
Thanks for the replies
Old Mar 25, 2008 | 05:42 AM
Wardamneagle's Avatar
Go to this link and read the section on electrical mechanism (about half way down).
http://carterswebsite.com/4runner/mods/locker/
Old Mar 25, 2008 | 05:43 AM
Marc P's Avatar
http://67.122.16.97/carterman/4runne...er/#ELECT_MECH
Old Mar 25, 2008 | 05:44 AM
Marc P's Avatar
You posted that link 1 min before me
Old Mar 25, 2008 | 07:01 AM
Sweet thanks for the link(s).
Old Mar 25, 2008 | 08:19 AM
Thumbs down
OK, now im totally confused. Im looking at the diagrams on a couple different sites, and I see that the pins labeled 1 and 2 are used for unlocking and locking the diff with a 12v source.
So I hook my volt meter the the ORS kit and when the switch is Down I get a 12V reading on pin-3 when the switch is Up I get a 12V reading in pin-4. WTF? Pin-5 is grounded.
And also the "carterswebsite" diagrams have two connectors, a 5-pin and a 2-pin. The ORS harness has 1 5-pin. The factory harness I have from the axle to the body has a 5-pin and 2-pin connector.
Old Mar 25, 2008 | 12:37 PM
Let me see if I can confuse you a bit more. A word of caution, I have never done this myself!
If you go to this link, you will find the Tacoma elocker wiring diagrams. These are the diagrams for your TRD elocker.
http://www.yankeetoys.org/Docs.htm
The TRD elocker has a 5 pin and a 2 pin wiring harness on the elocker which plug into a factory wiring harness which has one 8 pin connector on the other end. One of the pins is not used and two are grounds so normally you can use 6 conductor wire. I'm not sure how you're getting away with 5 conductor unless you are grounding at the elocker (which is fine BTW).
If you look at the elocker wiring diagram, you see two motor wires, LG-R and LG which are on pins 2 and 3 respectively. I think (but I'm not 100% positive) you put 12v on the LG wire to lock and 12v on the LG-R to unlock. The pin numbers that I am using are on the wiring diagram. Don't rely on the pin numbers, use the wire colors at the elocker.
Assuming that I am correct. If you want to lock it (I'm surprised it isn't locked as you normally install them locked), you need to ground the LG-R wire and put 12v on the LG wire. BTW, LG is light green, and LG-R is light green with a red stripe. To unlock, ground the LG wire and and put 12v on the LG-R wire.
Good luck and I repeat, I have never tried this!
Old Mar 25, 2008 | 01:16 PM
Alright, that would have confused me enough to give up... if I didn't just sit in my garage for 3 1/2hrs playing with the little motor. But what you say is fact and would have helped if I came insde and read your reply.
It works, after re-wiring, disassembling and completely restoring the inside (racing RC cars for years finally paid off) then lining up the little clutch system and gears and... ahhh what a pain but it works and I'm happy now. Thanks for the help.
Now I have to put the motor back in so I can test it out.
Old Mar 25, 2008 | 02:29 PM
Glad you got it working. Can you confirm my assumption that it's 12v on LG with LG-R grounded to lock and visa versa to unlock?
I'm designing an install with 2 TRD elockers on my 85 4Runner and I'm going to control it with an FZJ80 elocker ECU and switch. The 80 ECU will control two elockers. I'm trying to confirm a few of the pin to pin connections and that information would be of help.
Thanks.
Old Mar 25, 2008 | 04:24 PM
When I was testing the motor I hooked a 12V to the LG(1) and ground to LG-R(2) and the motor would rotate clockwise (locking). Switch the wires 12V-LGR GRND-LG and the motor would rotate counter-clockwise (unlocking). Hope that helps.
Old Mar 25, 2008 | 10:32 PM
That's perfect thanks!
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
1uzRunner
63
Nov 10, 2018 03:58 PM
accuracy
Sep 20, 2015 07:44 PM
Patrick1976
Sep 15, 2015 11:33 PM
zz_denis
Sep 6, 2015 03:43 PM
