e-locker?
Old Aug 21, 2007 | 05:59 PM
killa b's Avatar
e-locker?
just got a 2002 e-locker for 150 so i think thats a good deal. im contemplateing putting it in the front axel and doin a linclon locker in the rear or finding another one and running them front and rear. what is the lowest gear ratio that i can get for the locker. thanks for the advice
Old Aug 21, 2007 | 06:29 PM
cootees's Avatar
You are still on ifs right? You can't put it up front on ifs. It'll have to go in the rear.
$150 is a very good deal. I paid $450 for mine.
Old Aug 21, 2007 | 06:35 PM
killa b's Avatar
im goin to do a sas and i have an 85 axel sittin in my grage.
Old Aug 21, 2007 | 06:39 PM
PoleVaulter95's Avatar
having selectable up front is always a good idea for steering reasons. but thats all the advice i can give i have no idea what is involved in making it work.
Old Aug 21, 2007 | 06:41 PM
tc's Avatar
tc
Same gears as the preTaco axles - 4.1, 4.30, 4.56, 4.88, 5.29, 5.71
Old Aug 21, 2007 | 06:47 PM
killa b's Avatar
do the 5.71 hold up very good cause i was looking to go to 40s when i do the sas and would still like to drive it on the road to the trail and thanks for all of the advice.
Old Aug 21, 2007 | 06:48 PM
tc's Avatar
tc
As always, the lower the gear ratio, the more critical the setup.
www.gearinstalls.com
Where the hell do you wheel that you NEED 40's? Must be a helluva a mall ....
Old Aug 21, 2007 | 06:58 PM
killa b's Avatar
i want to be able to do alot more trails than what ive been doin. ive got 35s right now and been looking at trails that i cant do cause of my ground clearnce and i know ive got the ifs but even with the sas i still wouldnt be able to do those trails. does anybody have experiance running 5.71 in there truck thanks
Old Aug 21, 2007 | 07:30 PM
crolison's Avatar
what gears does the elocker have on it? and is it for the whole third?
Old Aug 21, 2007 | 07:55 PM
killa b's Avatar
whatever comes stock on a 2002 taco and yep for the whole third member.
Old Aug 22, 2007 | 10:17 AM
tc's Avatar
tc
I have 5.71's in the trail truck (SAS on 35's). I can tell you they are stronger than the stock Birfs...
Check out the AZ chapter of TTORA. Not many folks there are running tires that big and they do some of the gnarliest trails out there. Do some research, talk to captkirkyota on TTORA. 40's on Toyota axles is not a good idea.
Do you have lockers in both ends yet?
Old Aug 22, 2007 | 03:18 PM
killa b's Avatar
no thats what im planing on doing
Old Aug 22, 2007 | 04:50 PM
hud's Avatar
hud
In order of preference:
Two E-Lockers,
Put the one you have in the rear, then look for the high pinion e-locker to put in the front.
One E-Locker/ One Open
Put the E-Locker you have in the rear.
One E-Locker/One Welded
Put the E-Locker you have in the front (so you can steer), and weld the rear.
Some people say the 5.71s are weak..., but as expressed earlier, they are really plenty strong, and just as strong as 5.29s. A good setup can make a big difference, particularly cap bearing preload on the ring gear side (to minimize deflection).
Old Aug 22, 2007 | 06:53 PM
gixxerjesse's Avatar
i would sugest putting the locker in the rear leaving the front open and learn to wheel it. i dont know of any one who had 40's at TTORA TO and the ran some extramly gnarly trails, at most the bigest was 37's or 38's i think if you are running trails with a completly open dif truck and clearance is TRUELY your only problem with 35's you sir have some awsome driving skills
Old Aug 22, 2007 | 08:34 PM
tc's Avatar
tc
The AllPro buggy and Action Jackson's buggy had 39" Krawlers, but I don't think anyone else had over 37's...
Old Aug 22, 2007 | 08:40 PM
seanz0rz's Avatar
Guest
for those in the know, i did john bull and holcomb creek with my rig, last weekend. no locker, no sliders, 33 inch tires.
you can do alot more than you think you can just by choosing the right line, and having alot of confidence in your vehicle and the people spotting for you.
Old Aug 24, 2007 | 01:41 PM
Adam F's Avatar
If you don't have a locker in the rear yet, put it in the rear. That's a no brainer.
If you put it up front, plan on blowing up stock birfelds, or shell out $700 for longfields.
Old Aug 24, 2007 | 01:55 PM
tc's Avatar
tc
Well, not exactly. In my experience, the FRONT locker makes more difference than the rear, but yes there are more drawbacks (steering in particular).
I'm amazed by the number of people who seem to espouse that the minute you install a front locker that the CV's or Birfs will spontaneously explode. This is simply not true. There are a number of instances where having a front locker will control the wheelspeed much better and LIMIT the potential for damage.
Old Aug 25, 2007 | 05:25 PM
Adam F's Avatar
Not in his case. He said he was going to 40's. 40's with stock birfs and an elocker WILL explode birfs.
Old Aug 25, 2007 | 10:14 PM
tc's Avatar
tc
My point is 40's on stock birfs with or without a locker he's gonna blow stock birfs, not because he has a locker or not.
I wrote the post more for the people in the future who have reasonable ideas about tire sie that may come across this in a search.
