Dually Toyota?
It was called a cab and chassis. Sold by Toyota with just a cab and chassis, no bed of any kind. You usually see them as U-haul trucks, box trucks, flat beds, or RV's.
try giving this guy a shout:
Mike: 4xtoys@telus.net
he might have something for you, runs a toyota graveyard in Coalhurst AB
Are you sure a turbo booster won't work? The turbo booster has a smaller diameter than a V6 booster, but it's thicker.
My husband and I just picked up a toyota dually last night. 86 model with an actual bed sides and all, it looked to be factory made.. I can't tell any difference. Can't find any info on it at all. Any help is greatly appreciated as this is a project car. Thanks.
a booster from a 95 t100 without abs and 4wd will bolt right in.
i kno this for a fact becuz i have one on my truck. with a chevy master cylinder. and 4 wheel disc brake set up..
From what I understand, the ONLY dually rear end truck was sold as a cab and chassis. Then later they were converted to u-haul trucks, motorhomes, etc.
The 1 ton truck is just a single rear wheel.
All those beds on the dually rear end were aftermarket. Probably just a cab and chassis DRW with a custom made bed.
Sep 4, 2015 09:27 AM
