Driveshaft Spacer
Old Aug 30, 2007 | 11:17 AM
AlexJet's Avatar
Driveshaft Spacer
I need a driveshaft spacer. I looked everywhere, but couldn't find anyone who is making them for the latest 120 platform (FJ, 4th Gen. 4Runner, latest Tacoma, LC Prado). There are plenty of them for other vehicles, but nothing for Toyota.
Could someone suggest the place to get one?
Here are some pictures of what I'm looking for:
Old Aug 30, 2007 | 11:31 AM
WATRD's Avatar
I have to ask the related question... what have you done that you need to space your driveshaft? I have 9" of lift or so and the stock shaft still works fine.
Old Aug 30, 2007 | 12:05 PM
AlexJet's Avatar
Well... 4.5" on my rear and I'm out of extension when I'm jacking up the truck on the hoist. I have to put a tow strap around the rear axle when working under the truck to prevent the axle going full down and popping out the driveshaft.
Old Aug 30, 2007 | 12:15 PM
WATRD's Avatar
Hmm... there must be some differences between your '05 Runner and my '01 Tacoma in that area. I am at close to 9" of lift and have lots of droop and mine stays hooked up over the full range. I see LOTS of spline, but it stays hooked up. Odd.
Have you thought about having your shaft reworked to suit? It will cost a few more bucks, but it's really the "right" way to do it...
Old Aug 30, 2007 | 12:20 PM
AlexJet's Avatar
Re-do the driveshaft will cost at least $500-600 and another thing is that I don't know what mod I'll do in a year or so, so spacer is better and cheaper choice to do it. At the finish point when you've done the final stage you can work-out the driveshaft itself, it's the to do it.
Old Aug 30, 2007 | 12:45 PM
WATRD's Avatar
Well best of luck then, it sounds like you have your heart set on a spacer.
I had the same operation done on a driveshaft for well under $200 US a few months back, so you must have something pretty special in mind.
Old Aug 30, 2007 | 12:51 PM
AlexJet's Avatar
The question is ... Where to find it? ...
Old Aug 30, 2007 | 01:13 PM
Adam F's Avatar
I've never seen one for Toyota's either. Try www.aimind.com maybe, email them?
Old Dec 13, 2007 | 06:28 AM
azredliner's Avatar
The amount of lift is irevelant to the length of a driveshaft if you don't wheel your rig. I have about 7 inches of lift and I can flex my axle enough that the slip comes out. I found this article because I'm searching for spacers for my Yota.
Old Dec 13, 2007 | 07:24 AM
4Crawler's Avatar
Might have something in the works for this in the near future. What sort of range of thicknesses would you find useful? Was thinking of a couple of spacers in the range of 1/2" or 3/4", 1" and 1.5". Cost would be about $75-80 w/ longer hardware.
Old Dec 13, 2007 | 07:32 AM
AlexJet's Avatar
That's a good choice. I had to make my by custom shop. It's 1" and it cost me $150.
Old Dec 13, 2007 | 07:37 AM
azredliner's Avatar
$150.00 for one spacer? Screw that! I'm going down to the metal shop to get a foot each of 2.0" and 2.5" and build my own drivshaft.
I just bought some for my Samurai for $25.00 each.
Old Dec 13, 2007 | 07:39 AM
AlexJet's Avatar
yes, 150...
Old Dec 13, 2007 | 07:55 AM
azredliner's Avatar
I was thinking a guy could cut the bolt holes out of the Samurai spacer. I held a Toy flange to a Sammi flange and they are about an 8th off on each hole.
Old Dec 13, 2007 | 08:19 AM
tc's Avatar
tc
I had my front lengthened and rear shortened for $200 when I put the crawler in...
Oh - and too short and coming apart is a HELLUVA lot better than too long and destroying your tcase or diff.
Old Dec 13, 2007 | 08:25 AM
dropzone's Avatar
Fossilized
that is a pretty decent deal...curious at what RPM did they balance your shafts to? Seems like a lot of the shops around here only go up to about 500 rpms...will be doing the shortening/lengthening deal next month or so...
Old Dec 13, 2007 | 11:05 AM
tc's Avatar
tc
good question - I never asked, but don't have any vibration issues
Old Dec 13, 2007 | 11:43 AM
rdlsz24's Avatar
Maybe you can get a local shop to machine a spacer for you?
Rob
Old Dec 13, 2007 | 06:28 PM
AlexJet's Avatar
Rob
I did, $150
Old Dec 16, 2007 | 07:12 PM
4Crawler's Avatar
May have a spacer available first part of next year. Just getting ready to send out the flanges and dimensions to the machine shop. Probably be a little after the holidays to get something fabricated.
