Do you use oil between changes?
Old Nov 13, 2006 | 05:57 PM
uberhahn's Avatar
I switched to synthetic engine oil when I bought the truck about 20K miles ago. I've noticed that my oil level is low about a quart and a half between changes.
No leaks.
How many of you experience this? I've got 110K miles now.
No oil in coolant.
uberhahn
Old Nov 13, 2006 | 06:02 PM
91TPU's Avatar
its not totally uncommon to get some oil consumption on a motor with more miles on it, but a quart and a half are ridiculous. how often do u change your oil, your positive you dont have a leak?, and remember, your oil filter can hold a decent amount of oil in it, so attribute some to that.
Old Nov 13, 2006 | 06:06 PM
xonetruthcrewx's Avatar
its common for oil to be burned when you switch to synthetic oil on a high mileage engine that has always had regular oil in it. its blow by on the piston rings. no worries. your good to go.
Old Nov 13, 2006 | 06:32 PM
AH64ID's Avatar
When you change your oil do you run it for a few minutes and recheck it?
You should never let it get that low.......
I switched my 92 to synthetic at 150K, doesnt burn more than 1/4 qt per 2500 miles...
Old Nov 13, 2006 | 07:32 PM
youngbuck's Avatar
Try a different brand of oil. For some odd reason some engines burn certain brands more than other brands. What kind of syn oil is it?
Old Nov 14, 2006 | 11:28 AM
surf4runner's Avatar
i went from dino to synth blend to full synth (castrol) by 100K. the 1st syth change used a qt between changes and none inbetween changes since.
Old Nov 15, 2006 | 07:14 AM
X-AWDriver's Avatar
I've got 120k on mine and I go 9k between changes and it doesn't eat any oil.
Old Nov 15, 2006 | 04:09 PM
mburnickas's Avatar
Could be normal might not be. Depends on the oil used (aka Noack) rating. Some oils are nice and low (around 5 to 6.5) and some are high 12 to 15%
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Toyvana
Jul 29, 2015 10:47 PM
yourrealdad
Jul 29, 2015 11:08 AM
irritech
Jul 27, 2015 05:15 PM
calderp
Jul 27, 2015 09:58 AM
