Diff gasket/sealant
Old Aug 20, 2010 | 04:05 PM
mlrtime99's Avatar
Diff gasket/sealant
If you know what this is, than you know how pissed I am. Just finished the e-locker swap, used Permatex Ultra-Gray and I got a leak. I prepped both surfaces with brake cleaner, then rubbed with alcohol, then applied and even put rings around the studs, set the diff on, hand tightened and then wait an hour, then tightened down. I even let the damn thing cure for 3 days before adding fluid.
Where did I go wrong? I do have the gasket but the machinist said it would be a waste. Should I have gone with the ultra black? The only reason I with went gray is it said it was for high torque applications.
Speak up, it's my first time with FIPG and evidently I'm not good at it
Old Aug 20, 2010 | 04:54 PM
myyota's Avatar
You should have used ultra black, that`s what i used on my 4Runner and it has never leaked at all.
Old Aug 20, 2010 | 05:02 PM
scuba's Avatar
Ultra grey is where it's at. You said you hand tightened then waited an hour?
Last time I put a diff in, I torqued it down about half way, waited 20-30 mins then fully torqued. Haven't had any issues in 20K miles.
Old Aug 20, 2010 | 05:41 PM
gary_the_4runner's Avatar
i used ultra gray, i wasn't bashful with it, thats for sure! there is gray stuff comin out of ALL sides. i hand tightened it, let it vulcanize for about 30-40 min and torqued it down. did you tighten the nuts down sequentially in a circle(bad)? or in a star like pattern to mate the surfaces evenly(good)? at a glance it just looks like you didnt use enough material
Old Aug 20, 2010 | 05:48 PM
1990yota-pickup's Avatar
use the high temp red stuff.. you should never ever have a problem..
but if you want to know how to make a sealer out of some peanut butter, coca poweder creamer and some sugar... just let me know... and works better then rtv..
Old Aug 20, 2010 | 06:06 PM
waskillywabbit's Avatar
Toyota Black FIPG for diffs and oil pans
Toyota Red FIPG for trans/tcases
Nothing else necessary. It sets in about 15 minutes.
Old Aug 21, 2010 | 07:18 PM
soarerjzz30's Avatar
I've used all colors on the 3rd with the same results, no leaks! Hand tighten, then torque in a star pattern as stated above to 18 Ft lbs. This time don't wait to tighten.
Old Aug 22, 2010 | 04:49 AM
i've always cranked everything right down and never waited..
but the only time i do wait is when i mess water pumps and thermosat covers
coolant and rtv dont mix...
Old Aug 23, 2010 | 11:56 AM
mlrtime99's Avatar
Ya the ONLY thing I did that I wasn't 100% sure on, I used a "small" bead like the instructions said, thing I'm going to redo and SMOTHER the damn thing. Yep tightened it in a criss cross pattern like I use on my wheels
Old Aug 23, 2010 | 02:27 PM
you always have to tighten in a patteren or you cause warpage... and not get a good seal
Old Aug 23, 2010 | 08:07 PM
peow130's Avatar
when i put on my other diff a few months back i smother the thing so id have a nice bead of rtv hanging out the outside of the diff. doesnt leak. but unfortunately my pinion seal does -.-
Old Aug 23, 2010 | 08:51 PM
modlite's Avatar
I've done two now, i used Toyota Black FIPG. I just smothered it on and tightened them down evenly, no problems.
live4soccer7
May 11, 2016 06:52 PM
Badlander
Oct 10, 2015 08:05 PM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
zz_denis
Sep 6, 2015 03:43 PM
